Old 02-01-2014, 08:15 PM   #1
Move tv antenna crank arm?
Our TV antenna crank arms stops (when the antenna is down resting on the roof) in such a way as to block a cabinet door.
Is there a way to move the stop position roughly a quarter turn more?
Thanks!
Name:	ImageUploadedByForest River Forums1391303732.392178.jpg
All previous rigs below are sold - waiting until the kids graduate to the buy the next one!
'13 Forest River Sunseeker 3100 Class C
'04 Fleetwood Sedona Pop Up / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar Pop Up
paulmlac is offline   Reply With Quote
Old 02-01-2014, 08:23 PM   #2
Dovetail's Avatar
Could you just back it up a quarter turn. Guessing it would have minimal impact on antenna position.
Rick and Linda, Lindale, TX
2011 Flagstaff 8528 CKSS
2006 F350 SW
Camping nights 2013: 130
Camping nights 2014: 17
Dovetail is offline   Reply With Quote
Old 02-01-2014, 08:26 PM   #3
Ford Idaho's Avatar
I would pull the crank handle and see if it can be moved without issue.
I think there is just the one screw holding it on.
Old 02-01-2014, 09:59 PM   #4
rjf7g's Avatar
You can remove the handle with an Allen wrench and reposition it as desired. I can't remember what size fits it, but whatever size it is came in my standard Stanley brand set!
2006 Palomino Puma 27FQ Bunkhouse
2007 Gulfstream Innsbruck 36FRS Park Trailer
rjf7g is offline   Reply With Quote
Old 02-01-2014, 10:13 PM   #5
RPAspey's Avatar
Yup, just move it. 90 degree increments.
2000 Cherokee 31BH, "flipped axles and raised",LEDs, solar, inverter, etc..aka "boondock ready". '07 Tundra 5.7L DC-LB, modded as well.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 02-03-2014, 07:44 PM   #6
OP here with an update -
Yup, an Allen wrench loosens the crank arm so it can be rotated away from the cupboard door swing.
But I noticed that the whole antenna doesn't rotate. That's when the antenna is raised and you try to spin it around. So it's either frozen up (although was in the 40's when I was trying to move it), needs lubrication, was held up on something, etc.
When I try to spin the round thing in the coach, I can see through a vent that the antenna wiggles but it just doesn't move. Yes, I pulled the other piece down first.
Backstory is the antenna was removed and remounted so thinking its related to that.
Old 02-04-2014, 12:12 PM   #7
RPAspey's Avatar
Sounds like the crank gear is broken. A new one costs about $10 and takes 30 minutes to install. I found out the hard way not to "keep cranking the antenna up until you hear clicking" as I was told when I bought it. Now, I labeled the handle to only turn it 14 times to raise.
antenna
