Old 04-01-2015, 08:16 AM   #21
Hey Bob
I get somewhat unbalanced when I have had a couple of wines!!
saltyman is offline   Reply With Quote
Old 04-02-2015, 03:35 PM   #22
Herk7769's Avatar
You may need to remove the motor assembly from the air handler side of the air conditioner.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 04-03-2015, 07:04 PM   #23
I had a fan that made the same type noise. It turned out that the fan blade base had a tiny crack in right by the set screw. I was able to take the broke fan off and order a new one and fix it myself.
Bamamax is offline   Reply With Quote
Old 04-04-2015, 02:32 PM   #24
this noice is coming from the turbine looking thing under the Styrofoam. I cant even figure out how to open that up and look.
gr8white is offline   Reply With Quote
Old 04-04-2015, 02:53 PM   #25
bubbles's Avatar
Could that turbine looking thing be the squirrel cage fan previously mentioned?
Old 04-04-2015, 02:54 PM   #26
i believe it is but I cannot figure out how to get to it to see whats wrong. Here are some pics I took.
ID:	73060   Click image for larger version
ID:	73061   Click image for larger version
ID:	73062   Click image for larger version
ID:	73063   Click image for larger version
Old 04-04-2015, 09:14 PM   #27
Herk7769's Avatar
You will need to remove the motor and fans as an assembly, I believe.
Old 04-06-2015, 09:59 PM   #28
does anyone have instructions on how to remove this motor and get the squirl cage out?
Old 04-06-2015, 11:38 PM   #29
Left Coast
Looks like the condenser housing, the tin part the fan housing is mounted to, will have to be have the condenser removed for access. Kinda looks like , 2nd to bottom picture, the housing might separate there. If it's made like a lot of cars, some times the spot welds have to be drilled out and replaced with screws. I'd like to see a little more of the tin where the tubes are coming out.... from the side you're showing and ,same end, the other side.
Old 04-07-2015, 12:36 AM   #30
Crockett's Avatar
pretty sure i just remove the 4 screws holding the evaporator and flex it gently asside to pull the blower wheel.
edit: can you just spin the fan and inspect it with a light? should be broken/missing blades. they dont bend like the old metal ones
Crockett is offline   Reply With Quote
