Old 10-30-2015, 09:25 PM   #1
Love My Sunseeker
DXSMac's Avatar
My MagnaDyne is all messed up!
I have a Sunseeker 2013 Model 3170. I recently had it in a body shop for a week to repair a stress crack under the front slide. The Magna Dyne was working before I brought it in, and there was no reason for the body shop to mess with my MagnaDyne.
The GPS is working, but I cannot get any sound from the radio. Ok, let's just say, when I turned the VOLUME up, all of a sudden I heard a "pounding" coming from under the dinete seat, and I didn't know there was a speaker under there, as I have a drawer under that dinette seat! But there was a POUNDING when I turned the volume up. Turn it down, no more pounding. but NO SOUND coming from the speakers in the driver and passenger entry door.
Ok, I went to the radio, fussed with the EQ button, got the grahpic equalizer up, and pressed and pressed and fussed, and finally got SOUND to come out of the CENTER speaker above the TV (and I'm playing the RADIO!) but still no sound coming from the speakers in the driver and passenger door.
Is there anything else I can do?
I am hoping the body shop people did not mess with my MagnaDyne.
I haven't tried to play a DVD yet. I will try that tomorrow.
Ok I'll mention this in case it had something to do with it. My RV had been at the body shop for 10 days. When I picked it up, my coach battery was completely dead! The body shop rep didn't have a clue why the coach battery was dead. No reason for it to be. On the other hand, I did have a small item plugged into the 12 volt outlet under the dinette. The item was a 12 volt USB adaptor. Nothing was plugged into the USB adaptor, but the adaptor was plugged into the 12 volt and it had a small light on it. Is it possible this TINY thing ran the battery down (because of the small light) and the battery running down is why my MagnaDyne is all messed up?
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 10-30-2015, 10:17 PM   #2
2012 Solera
Changed out my Magnadyne a couple years ago, but, as I remember, there is a "straightened paper clip" reset hole, I think in the lower right corner of the face of the unit. Had to use that several times on mine.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 10-30-2015, 11:17 PM   #3
Love My Sunseeker
DXSMac's Avatar
I've already used that "ball point pen" hole a lot. I use it when the GPS loses memory. It seems to lose memory when you play a lot of CD's or play DVD's a lot.
Pressing the "ball point pen" reset hole didn't fix this issue......
Old 10-31-2015, 12:11 AM   #4
Delco Bobby's Avatar
Some thoughts:
Did you try adjusting your balance and fade controls?
Perhaps the speaker wire connectors came loose during the repairs.
The body shop people may have been listening to your radio while they worked. Do you have speakers on the outside?
If they were listening to the radio then that could be one readon why your battery was dead. There may be other things that use power that are not usually noticed. TV's on standby. My 2015 Ford manual says to unplug all chargers when the car is not running to avoid a battery drain.
Perhaps they used your outside outlets as a power source but I think they only work when you are plugged in to 110V AC.
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
Old 10-31-2015, 07:56 AM   #5
Love My Sunseeker
DXSMac's Avatar
Originally Posted by Delco Bobby View Post
Some thoughts:
I'm going to try that again. I tried to do that when I had it in EQ mode, but I don't think I quite got that far.
I hope not!
This thought crossed my mind. But all the radio stations were "reset" to static noise, even the stereo in the center of my RV under the middle TV.
I had a small "12 volt USB adaptor" plugged into a 12 volt outlet under dinette. This small USB adaptor had a small light. Nothing was plugged into the USB adaptor, but it was still plugged into the 12 volt outlet. I'm wondering if that tiny thing ran down the battery.
I don't think this was the situation. I don't have an outside speaker, but I sure didn't know there was a speaker under the dinette!
Old 10-31-2015, 08:11 AM   #6
If the repair shop won't fess up, assuming they had something to do with it, and barring a coincidence, don't waist anymore time on, what if this, what if that. Look into a good auto audio shop that does installations. They will be able to trouble shoot your issue way faster. Then, based on what you find out, you may have recourse against the repair shop, if in fact it was a related occurance. You would need documentation from the audio shop as what was the issue, if it ends up being related to procedures utilized to repair "stress cracks", whatever that means. Just sayin'
Old 10-31-2015, 11:53 AM   #7
vasnipe's Avatar
House battery dead
DXSMac -
There are a couple of "parasitic" loads on the 12v system even when everything looks like it is turned off. The LP alarm and the Carbon Monoxide alarm draw a minute current along with the radio, etc. This current draw is enough to draw a battery down in a week to 10 days.
Herk and some others can chime in if I have missed anything.
Now, as to the Magnadyne, I do not have a clue, my 2006 Sunseeker did not come with that system.
Good luck.
Chris in Virginia
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
vasnipe is offline   Reply With Quote
Old 10-31-2015, 12:33 PM   #8
I hope not!
I just remembered that my Magnadyne was making a similar noise one day as I walked by the RV. It sounded like someone was on the roof, once I determined that the roof was clear I was concerned that someone was in the RV. Nope. then I noticed that the screen on the radio was flashing along with the deep noise which sounded like it was coming from the ceiling although I don’t see speakers there. I think I only have dash speakers. Eventually got it to stop which may have happened after I plugged it into shore power.
Next day the radio worked fine after I started the engine.
These radios have quirks which I learned from the service manager at my RV dealer after mentioning the above to him. His dealership rents Sunseekers and he has received complaints about the radios. Others there did not know this.
Some of the quirks are:
What you described and what I experienced, probably the same thing.
The radio turning itself on randomly when no one is minor near the RV. I had this happen a few times.
Losing the preset stations. Twice for me.
Radio sometimes will turn on after starting the engine and other times will be nice and wait to be turned by a human. lost count on this.
Check to make sure your antenna is screwed on all the way and the threads are not dirty.
Tune in a strong station in your area.
Does your problem occur when plugged into shore power or with the engine running. These radios will act up when the house battery gets low. The radio will work with shore power or with the engine running.
Maybe a system reset will help. This is from the Magnadyne user manual for models M3-LCD and M4-LCD:
To reset
1. Press the button to reveal more setup features.
2. Type “5365” as the passcode then press the OK button.
3. The unit will reset the radio area and wallpaper to factory default settings.
2018 Ford F-150
Old 10-31-2015, 12:55 PM   #9
Mikegjax's Avatar
The speaker behind the dinette drawer is the sub woofer. It is against the out side wall. You should have an A/B switch in the side of the cabinet just above the kitchen sink. Try different positions on the switch to see if it makes a difference. Your Magnadyne is powered from the coach batteries if yours is like my 2014 R. With the battery switch off you should not have power to the radio (easy test). Make sure you batteries are charged then try the radio.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 10-31-2015, 02:12 PM   #10
Garrette's Avatar
If you have a ABC speaker selector switch, turn it to C position. B position turns cab speakers off. The A position, who knows.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
