Originally Posted by Daniellekristopher
Was doing some multimeter testing on my fuses attempting to troubleshoot an exterior lighting issue. While doing so, I discovered that the MyRV panel is pulling 27mV across a 20 amp fuse. This equates to 8 Ah. Seems a bit high. Does anyone know if this is typical?
Without knowing the exact resistance value of the fuse you are measuring a voltage drop across, there is no way to accurately calculate the current draw of the load. The rated amperage value of the fuse has no bearing on the calculation.
The most accurate way to determine the current draw is to remove the fuse and using the current function of the DMM measure the actual draw of the load by connecting the meter in place of the fuse. Be sure to set the DMM to DC amps mode and move the leads to the correct positions on the meter.
Most low cost meters will be inherently inaccurare at the low currents you will be finding.
