Old 05-31-2019, 12:30 AM   #1
Mystery with Suburban furnace
Greetings all, this past trip we could not get our SF 30 to run. We checked the fuse and that was in tight, removed it with pliers and it was in good condition so put it back. Voila, the furnace started right up and worked fine for the entire trip. When we returned home we turned the furnace on to keep the lines from freezing since winter has a death grip on CO. and again it wouldn't work until we pulled the fuse and then put it back in and then it worked great. Is there a reason that we are having to pull the fuse and re seat in order to get the furnace to work, and what might the fix be? Thanks for any and all input.
Mamacast is offline   Reply With Quote
Old 05-31-2019, 06:24 AM   #2
A32Deuce's Avatar
Pulling the fuse and putting back in is cleaning the contact points and remaking a connection. Next time try a little dielectric grease on the contacts.
A32Deuce is offline   Reply With Quote
furnace, suburban
