Old 09-05-2012, 07:54 AM   #21
Road-King's Avatar
Devi1Dog,
I can't find a Konka with that model number. Did you get the number off the remote or TV itself? The reason I ask is that looks like a model number for the remote. It should have the model # XXXXX (example model klc 1508u) the back of the tv set.
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 09-05-2012, 08:23 AM   #22
VinceU's Avatar
Originally Posted by Road-King View Post
Devi1Dog,
Road King try this "KDL32MS82A LCD TV " right off the websight.
Old 09-05-2012, 08:34 AM   #23
K. I will have to check when I get off of work tonight. It's probably on the tv but it's bolted up on a extending arm so I will unbolt it and see.
Devi1Dog is offline   Reply With Quote
Old 09-05-2012, 08:48 AM   #24
Road-King's Avatar
According to the Konka web site that model has a audio out. I sill cant find the manual on that model number, but looking at one model in the same series, it looks like the audio out should be on the right side of the jacks panel just left of the coax hookup. Labeled AV Out, with a yellow, red and white jack. You will need to connect a RCA cable from the red and the white to the Genesis.
On the Genesis the RCA cable should hook up to; white RCA to AV1-L and the red RCA to AV1-R. On your Genesis remote press the "Input" button until the Genesis display says AV1.
That should do it.
Russ & Kim
2014 Alpine 3600RS
Old 09-05-2012, 09:00 AM   #25
Road-King's Avatar
VinceU,
One more thing, if there is something already plugged into the Genesis at AV1, it is most likely the "Gaming Plate" mounted in your entertainment center, if you have one. You could disconnect this or try another input like AU2 or AU4.
Russ & Kim
2014 Alpine 3600RS
Old 09-05-2012, 09:02 AM   #26
Road-King's Avatar
Work? What is that? Oh yea I remember now....
Russ & Kim
2014 Alpine 3600RS
Old 09-05-2012, 09:16 AM   #27
CampingQueen
Here's pics of how mine is setup (from the factory). Not sure if it's the same TV, but it is a Konika also. Maybe this might help?
The top picture shows the jack where the audio out is located. It's the one labeled "SPDIF/AUDIO OUT" on the right hand side of the back of the TV, going up and down. The inputs on this TV are not in the same area - they are going right to left along the bottom rear of the TV.
This shows the way they have it hooked up. The red/white standard audio cables are plugged into a 4-way green adapter. Not sure what type of adapter it is. The green adapter has one male end and three females. You can see the red/white audio cables are plugged into the red/blue female ends of the green connector.
2012 Flagstaff V-lite 30 WTBS
2011 Ford Expedition
4 kids and a hubby & never enough time to camp!
2011: 17 nights 2012: 26 nights 2013: 46 2014: 20 2015: 16
arlee453 is offline   Reply With Quote
Old 09-05-2012, 11:02 AM   #28
Road-King's Avatar
If you have the setup that arlee453 has, a headphone to RCA adapter should work, like this one
Two MP3 aux Player 3.5mm headphone Audio Rca Cable on eBay!
You can get them cheep at Radio Shack, Wal-Mart, etc...
I don't know what that green plug is for. Looks like it is not needed...
Russ & Kim
2014 Alpine 3600RS
Old 09-05-2012, 08:13 PM   #29
It's a konka model# WDL26LS612U.
Old 09-05-2012, 08:46 PM   #30
K got the audio to work. Yayyyy!!! I plugged a whte/red RCA jack with the headphone 3.5mm jack in and it works. Now I gotta figure out why I lost color on the DVD side. Lol. What fun this is.
