Old 05-18-2015, 03:48 PM   #1
Need help on new speakers!
This past weekend I finally took out the brand new trailer and decided to turn on the tunes. I noticed that one of the speakers did not work. So I took the speaker off and when i shook it it started working. reinstalled it on the ceiling and five minutes later it was not working. I have the 17BH Clipper and the only problem I am seeing to replace the speakers is the washroom door opens right above the speaker. Does any one know of a good speaker that would fit there? it would be greatly appreciated!
2011 Gmac Acadia
2016 Coachman Clipper 17BH
hexmex357 is offline   Reply With Quote
Old 05-19-2015, 05:10 AM   #2
I just replaced the crappy Jensens with a set of Kenwoods on my new 17FQ.. They are round but just a little larger in diameter.. I had to cut a little to make them fit.. They do not interfere with the door...
Joe
meganjoe is offline   Reply With Quote
Old 05-19-2015, 10:56 AM   #3
Thank for the response meganjoe! I called Viking for the specs on the speakers and they told me they were 5 inch diameter speakers. I would assume Joe you bought 6.5 inch. I went to amazon and found some cheap JVC's for the time being! Hopefully everything works out.
2011 Gmac Acadia
Old 05-19-2015, 11:11 AM   #4
Boss Ox & Drovergirl
oxcamper's Avatar
If it's a brand new unit and you want the speakers to work, why not take it back to tthe dealer for a warranty replacement?
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 05-19-2015, 07:44 PM   #5
@oxcamper the speakers are so cheap that buying new ones is actually cheaper than hooking my camper up and driving one hour there if traffic is good! I would at least spend more than twenty bucks in gas alone and eat up most of my day! Plus I think with the JVC speakers, I might get a better sound quality inside.
2011 Gmac Acadia
Old 05-20-2015, 01:44 PM   #6
Speakers
I would check the crimp connections to make sure they are actually crimped tight. It may not be the crappy speakers
I attached the 12 volt battery for the first trip of the season and the ground wire fell off. I think whoever crimped the wire used a pair of tweezers.
On the last trailer, the receiver picked up stations up to 10 miles away. I ended up pulling the radio and soldering the antenna connector.
RussPastuch is offline   Reply With Quote
Old 05-20-2015, 03:40 PM   #7
Same sort of topic....
New to the RVing, would like to replace AVReceiver one that has HTML in plus Bluetooth or equiv to take music from iPhone, any suggestions, Tks, Greg in canada
gmoney is offline   Reply With Quote
Old 05-20-2015, 03:52 PM   #8
Denver, CO
garbonz's Avatar
I got some great low profile Speakers from Crutchfield that fit in the cabinet bottoms AND a pioneer Multimedia receiver (no CD player). Added a subwoofer in a bottom of a cabinet with a sub amp and AM very happy.
Retrosound R-525N speakers
Pioneer MVH X370BT
2017 Fuse 23T
Old 05-20-2015, 03:57 PM   #9
Tks, AVR has to be Slim line type, space is about 41/2"
Old 05-21-2015, 01:47 AM   #10
HTML?? Do you mean HDMI??
