Old 11-11-2018, 09:25 PM   #1
Need Help Trouble-shooting Solar
Had our Geo Pro out boondocking this weekend only to find something went wrong with our solar system.
Have a 160W panel on the roof (not sure of brand), a Go Power 30amp controller and 2 6v interstate flooded batteries. Everything in its first season of use.
Had a less than optimal exposure, ie faced in a way that the roof top ac unit always cast some shade on the panel, but located in AZ and had cloudless skies with a good 8+ hrs of sun daily.
The main symptom I observed was that the Go Power controller would show .5amps by 8:30 am but would never go higher even as the sun rose and panel shadowing reduced. volts never rose higher than 12.6. Over 3 days of camping with very conservative use of 12v, according to the Go Power, batteries dropped to 73%. After a 2 hr drive home, batteries were at least 90% again.
My theory is that the controller is failing to recognize when the batteries drop and is not directing the power to recharge them.
I need some help and suggestions in trouble shooting this to determine exactly what is wrong and then how to fix if possible, or what to replace.
lamokadave is offline   Reply With Quote
Old 11-11-2018, 09:47 PM   #2
If you have any shadows on the panel, you will basically get no output.
Show us a picture of your panel on your roof.
If you only have one panel, why is it next to your AC or is it because your roof is very small?
I was going to have a shading issue on one of my panels but I just made a taller mount to clear a vent and I was able to mount it away from the AC. You can also make a really tall mount and put it above your AC. Just has to be a strong mount.
Have you measured the panel voltage where it enters the controller?
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is online now   Reply With Quote
Old 11-11-2018, 10:06 PM   #3
I've had some good experience with this setup.
Even with some shadowing, worse than I had this weekend, I'll still get between .9 and 1.5 amps.
I did pull the controller off the wall and put a self ranging digital multi meter set to DCV but couldn't get a reading. I found that odd being the controller indicated some current was flowing so I expected to be able to measure some voltage
Old 11-11-2018, 10:33 PM   #4
Hi,
A partially shaded, presumably flat mounted panel (with presumably nice tight connections).
Before I tinkered around too much, if it were me, I would find some way to get that panel in full overhead sun and then get some fresh amperage and voltage measurements.
Rich Phillips
Rich Phillips
2009 K-2500 Duramax
2014 Silverback 33RL
richp is offline   Reply With Quote
Old 11-12-2018, 12:15 AM   #5
rk06382's Avatar
Any shadow on your solar panel will cancel any power from it. See this youtube video:
What effect does shading have on Solar panels?
I have six 100 watt solar panels in parallel to avoid shadow. At least one will not be in a shadow.
My roof panels:
Name:	Solar Panels 20180613_175256.jpg
The panels on the right will not produce any power because of the shadows on them.
Robert
2018 FR3 28DS
Samlex EVO-2212 Inverter/Charger | 400ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | Dometic 320 | SnapPads
Retired: Alaska Army NG
rk06382 is offline   Reply With Quote
Old 11-12-2018, 02:26 PM   #6
This is exactly why I chose to put all 6 of my panels in parallel rather than series. Shading can eliminate all panel output. As suggested, you need to get this panel in full sun, unshaded, and check the output then. Your charger will not decide whether or not to charge. It will provide a charge voltage if it can, although it should slow to trickle charge as the battery is full.
[SIGPIC]
2005 Coachmen Sportscoach Encore 380DS
2014 Jeep Wrangler Rubicon Unlimited
CharlieS3 is offline   Reply With Quote
Old 11-12-2018, 03:33 PM   #7
watching this
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
Philkaty is offline   Reply With Quote
Old 11-12-2018, 04:03 PM   #8
TBarbs
X2. Good info.
tbarb is offline   Reply With Quote
Old 11-12-2018, 04:03 PM   #9
Thanks for the video as it has convinced me to agree that my problem is simply shadowing as several have suggested. I was reluctant to accept that as in the past I'd have shadowing but always got an amp or more under that condition. The difference now though is the angle of the sun in Nov vs summer.
Old 11-12-2018, 04:09 PM   #10
Here's a shot that is only producing .4 Amos
https://photos.app.goo.gl/xALYUHyYxtENJ6BW9
solar
