Old 09-02-2015, 12:10 AM   #1
Sagecoachdriver's Avatar
New Forester, No signal left turn camera now
The cameras were all working when I left the dealer yesterday afternoon with my NEW Forester 2701DS. This morn, I got in the cab and started up the engine and I was going thru the little manual for the cameras and seeing what the remote does. I immediately got a "NO SIGNAL" on AV1 for the left side camera. The rear and right cameras work fine. The manual says to try a HARD REST by unplugging all cables and power cables from the multiplexer for 1 minute and then re-connect. Then check for tight connections.
Where is the multiplexer? I have looked under the dash on both driver's and passenger side, under the seat and under the hood. I don't want to take it back to the dealer for just a loose wire or needing a reset.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 2 trips 7 nights
Sagecoachdriver is offline   Reply With Quote
Old 09-28-2015, 08:23 PM   #2
After much reading on the forum, I found the multiplexer under the dash and checked all the connection. still had the problem of periodic "no signal". I finally was able to remove the cover on the mirror arm and check the connection there. I was able to push it in slightly. I unplugged and replugged it and put cover back on. Been on a 4 day trip, no problem since!
Old 09-28-2015, 08:38 PM   #3
Forester Fred's Avatar
Out of curiosity, how did you remove the cover on the mirror camera?
2015 Forester 2301 - Chevy
Skip & Deb
Forester Fred is offline   Reply With Quote
Old 09-28-2015, 10:05 PM   #4
Yes, I removed the cover at the camera and found the wires secured with screws. It was removing the cover in the middle of the arm that was the problem until someone on the forum told me I needed an allen wrench. Came off with a little wiggling. Again, I reconnected the plug and no more 'NO SIGNAL" since.
forester
