Old 06-21-2016, 03:48 PM   #11
W5CI's Avatar
Bob, where did you get the Ladder mount for the Tailgater, I want one
Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 3
W5CI is offline   Reply With Quote
Old 06-21-2016, 04:00 PM   #12
Left Coast
ID:	111728No remote YET.....have RF remote on slide and awning, and next will be stabilizer (2), and landing gear....
Sent from my XT1585 using Tapatalk
Old 06-21-2016, 04:02 PM   #13
Left Coast
Draft got in here...sorry...made it out of oak...this one for pin box
Old 06-21-2016, 04:04 PM   #14
Left Coast
Bottom of flex has 4 legs that one can tap out to 1/4" ,
Old 06-21-2016, 04:05 PM   #15
Left Coast
Added a platform under it, now can swivel....
Old 06-21-2016, 04:07 PM   #16
Left Coast
Then ran coaxClick image for larger version
Old 06-21-2016, 04:09 PM   #17
Left Coast
And have screw on caps for connectors....helps protect 'em
Old 06-21-2016, 04:14 PM   #18
Left Coast
These are under awning area....sorry bout dirt, but on 7200mile tripClick image for larger version
Old 06-21-2016, 04:19 PM   #19
Left Coast
There's another connector that the cord is covering up....so if flex is mounted on pin, I use the F connector, and when on ladder, use the hidden one marked R....also have a shelf for the receiver box to sit on same rail as this Click image for larger version
Old 06-21-2016, 06:17 PM   #20
qwkzotc's Avatar
Originally Posted by DocP View Post
Yes, but isn't the Wineguard G2+ just standard definition with DirecTV? It is my understanding that it cannot pick up the HD (high definition) signal. I put the more expensive Wineguard trav'ler high definition system up on my Class C roof so I could get the HD signal, but if I had it to do over again I would go with a less expensive setup.
True if you use the G2 for DirecTV it is SD only. However, if you connect it to a good TV then the TV will upconvert the signal to a very good picture quality.
The G2 can also accommodate DISH SD and HD. So you could use it with their Pay as you Go plan, only paying for the months that you use it, and get HD that way.
And, if you are in the forest you will be glad you got the portable unit instead of a roof top model for sure. The G2 comes with a 50 foot cable and I have needed every bit of distance on several occasions.
Dan
2014 Palomino Puma 19RL
2012 Toyota Tacoma with TRD SC
Husky Centerline WDH
Firestone Ride Rite Airbags
Winegard G2 Portable Satellite
qwkzotc is offline   Reply With Quote
satellite
