06-21-2016, 06:48 PM
#21
A friend of mine also recommended Winegard's trav'ler antennas. He said it works great. In fact, I never thought there were so many options for TV antennas.
"A creative man is motivated by the desire to achieve, not by the desire to beat others."
-Ayn Rand
06-21-2016, 06:59 PM
#22
Left Coast
I've tried 100' and had no negative results...
Sent from my XT1585 using Tapatalk
06-21-2016, 07:57 PM
#23
Originally Posted by DocP
Yes, but isn't the Wineguard G2+ just standard definition with DirecTV? It is my understanding that it cannot pick up the HD (high definition) signal. I put the more expensive Wineguard trav'ler high definition system up on my Class C roof so I could get the HD signal, but if I had it to do over again I would go with a less expensive setup.
Yes, it is just SD. We were actually going to buy the trav'ler. That is the one the salesperson talked us out of. I'll stick with SD for now to save the $1500. The other reason was the ability to move the portable unit. If you get a spot that has the southern exposure blocked, the trailer won't be able to get signal. I also was a little hesitant to drill holes in the roof of my brand new 2017 travel trailer.
Time will tell if the SD will be good enough or I will later want to move up to HD.
06-22-2016, 12:57 AM
#24
FWIW, if using SD only on DirecTV, I recommend going to your DirecTV menu/Display/Preferences and select the option to "hide HD Channels". This will remove them from the guide so you will only see the SD channels. If you don't do this and you input a channel number to your remote it will go to the HD channel and not find a signal, forcing you to open the guide and move the selection to the SD choice.
Enjoy! Dan
2014 Palomino Puma 19RL
2012 Toyota Tacoma with TRD SC
Husky Centerline WDH
Firestone Ride Rite Airbags
Winegard G2 Portable Satellite
06-22-2016, 08:58 AM
#25
Still can't figure why the Travl'r couldn't be portable.
FROG AR-0019-242
06-22-2016, 11:27 AM
#26
Enjoy! Dan
I have an old SD only box so this is not an issue for me.
06-22-2016, 11:37 AM
#27
Left Coast
D-12?
06-22-2016, 12:35 PM
#28
Originally Posted by W5CI
Bob, where did you get the Ladder mount for the Tailgater, I want one
Fantastic idea, I've seen one or two similar to that made out of alum tubing.
06-22-2016, 12:57 PM
#29
Left Coast
Hahaha......some just can't afford that high dollar stuff!.... ...And, have to dumpster dive to come up with other folks cast-off scraps....
