Old 12-02-2013, 10:53 AM   #1
No AC or Heat Pump
Went to turn on the heat pump last weekend and didn't hear it turn on. You hear a quiet "click" then nothing, same when trying AC so I figured it's something wrong with the AC unit.
Any suggestions on where I should start troubleshooting? Maybe a loose wire somewhere?
2011 Forester 3171DS Pic
SOLD!
New Rig: 2018 Tiffin 32SA
torino421 is offline   Reply With Quote
Old 12-02-2013, 12:11 PM   #2
Average Joe
MrJoe's Avatar
What is the outside temperature?? Mine locks out around 30 degrees.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 12-02-2013, 12:15 PM   #3
It wasn't near that cold, later in the day when it was warmer I tried the AC with the same result.
SOLD!
Old 12-07-2013, 09:02 PM   #4
Pull the fuse for the heater for a minute and plug it back in. It is a 12 volt fuse. This will reset the thermostat. While you are there turn off the breaker for the ac and turn it back on. Mine would run the furnace instead of heat pump when switched to heat pump. Resetting it did the trick.
Priusron is offline   Reply With Quote
Old 12-28-2013, 02:39 PM   #5
It was time for my monthly 2 hour generator run so I pulled the fuse labeled "furnace" and turn the break off for the AC unit then back on.
There was no other fuse labeled anything heater related
Didn't think the furnace fuse had anything to do with it but now the AC unit is working. Must have been turning the breaker on and off.
thanks for the suggestion!
SOLD!
Old 12-28-2013, 06:09 PM   #6
The furnace fuse is also for the thermostat power. You just reset everything.
pump
