Old 05-18-2011, 12:44 AM   #11
Nigels's Avatar
Originally Posted by BOBFIDY View Post
Hello Nigel. Hope all is with you and Bev.
Bob and Nancy
Hi Bob, doing fine, we are in BC at last and got our plates, so chilling out a bit. Just got the surround sound working thanks to this thread, Bev sends her love see you at the next FROG!
Nigel & Bev
Brit Driver & Canadian Naviguesser
2011 Rockwood Signature Ultra Lite 8280ws
2011 Dodge Ram 3500 4x4 Diesel
Nigels is offline   Reply With Quote
Old 05-19-2011, 07:04 AM   #12
Herk7769's Avatar
On my TV, the top two RCA plugs are left and right video outputs and go to the AV2 input on the back of the concertone.
HAM CALLSIGN - KC3FFW
Old 05-19-2011, 07:37 AM   #13
on my TT the tv isn't hooked to the centertone only the dvd has sound through speakers...
good luck from what I have read as far as getting the tv to work through the speakers.....
2009 F150 SCREW4x4 Prodigy P3 and tow package Valley WDH and dual anti sway
2006 Party Barge 21 90 Merc Optimax
2011 RockWood 2702 SS arrived 11.10.2010
nights camped 2010 6
threegr8katz is offline   Reply With Quote
Old 05-19-2011, 04:26 PM   #14
Owner - RVtronics
Bob Fields's Avatar
Send a message via AIM to Bob Fields Send a message via Skype™ to Bob Fields
Originally Posted by tom.keith View Post
Just bought a 2010 (new) Flagstaff 8528RKS with 32" Toshiba & Concertone ZX700. Adio on ZX works fine when in radio, CD or DVD but when I switch ZX to aux 2 I receive no audio from TV through that unit. I looked at cables, both on TV and on ZX & both appear to be hooked correctly. I did send Concetone an e-mail today, but after reviewing all the great info. here, thought I would give this a try also. Thanks
The standard installation from the factory has the audio OUTPUTS from the TV going to the Concertone, typically AU2. This feature is tested before the RV leaves the factory so it worked at time of build.
Sometimes we have seen the dealers remove the TVs so they don't get stolen and when reinstalled, they plug the Red & White Audio cables into the SAME TV INPUT that the Yellow Video Cable is plugged into. It is a common misunderstanding.
But the audio cables must be plugged into the TV Audio OUTPUT. Are you 100% sure this is the case?
If so, then you will need to double check the connections from the TV all the way to the back of Concertone.
Do the cables from the TV go into the wall or a Wall Plate?
If a Wall Plate, is that setup properly?
Let us know.
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
Bob Fields is offline   Reply With Quote
Old 05-19-2011, 11:43 PM   #15
Nigels's Avatar
Let us know.
Quite right Bob. RVW collected my rig from FR and the TV was still in the box, RVW installed it and made the same mistake, obviously never checked it.
Nigel & Bev
Old 05-21-2011, 04:03 PM   #16
Update on no audio from TV to ZX700
Thanks to all for your help. Reminds me of how struck we were a few years back when we started our winter travels, just how amazing fellow camper were, always helpfull.
Problem solved !! Thanks to my 15 yr. old grandson !! I was turning volume all the way down on T.V., assuming volume was controlled by ZX. When I turned volume up on T.V. it also came through ZX. Then selected menu item on Toshiba T.V. that lets you select to turn off T.V. speaker and now I have audio only through the ZX.
Thanks again.
tom.keith is offline   Reply With Quote
