Old 05-15-2011, 01:54 PM   #1
No Audio From Toshiba via AX700
Just bought a 2010 (new) Flagstaff 8528RKS with 32" Toshiba & Concertone ZX700. Adio on ZX works fine when in radio, CD or DVD but when I switch ZX to aux 2 I receive no audio from TV through that unit. I looked at cables, both on TV and on ZX & both appear to be hooked correctly. I did send Concetone an e-mail today, but after reviewing all the great info. here, thought I would give this a try also. Thanks
tom.keith is offline   Reply With Quote
Old 05-15-2011, 01:59 PM   #2
Check Aux1 on ZX700 - might be there. Has been reported here that tv audio out is not always connected to where you expect it to be.
...VTX-AL
VTX Al is offline   Reply With Quote
Old 05-15-2011, 03:13 PM   #3
sherdep's Avatar
my guess is that they only have video output going to your TV and no audio
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 05-15-2011, 03:58 PM   #4
BOBFIDY's Avatar
From having met Bob Fields at the FROG Rally a couple weeks ago...I'll bet he will get back to you and get your problem fixed.
He IS one of the good guys...IMHO.
BOB
2011 FORD F350 CREW CAB DUALLY DIESEL 4x2
2010 Salem LA 292FKDS
One of the Original 14 F.R.O.G.s
1st, 2nd, and 3rd INTERNATIONAL F.R.O.G. RALLY Branson. MO.
1st, 2nd, and 4th INTERNATIONAL RALLY Goshen, IN.
BOBFIDY is offline   Reply With Quote
Old 05-15-2011, 04:01 PM   #5
Thanks..did check back of unit and it cables were going to aux 2.
Old 05-15-2011, 04:09 PM   #6
buckisland1950's Avatar
See if this helps. Problem with Toshiba Audio thru Concertone Revealed. It was my problem......
2011 F250 Lariat Crew Cab 6.7L Diesel
2011 Flagstaff Classic Superlite 831 FKBSS
Fleet of Canoes and one Kayak
So Many Rivers so Little Time!
buckisland1950 is offline   Reply With Quote
Old 05-15-2011, 05:35 PM   #7
Buckisland 1950: I had reviewed your great post and it prompted me to look at the cables on the back of both units. The back of my Toshiba is not layed out the same, but my red & white rca cables are connected to the toshiba audio out pegs.
Old 05-15-2011, 05:41 PM   #8
Just a shot in the dark. Hope someone else has the answer for you......
Old 05-18-2011, 12:18 AM   #9
Nigels's Avatar
Thanks it fixed my problem too.
Nigel & Bev
Brit Driver & Canadian Naviguesser
2011 Rockwood Signature Ultra Lite 8280ws
2011 Dodge Ram 3500 4x4 Diesel
Nigels is offline   Reply With Quote
Old 05-18-2011, 12:33 AM   #10
BOBFIDY's Avatar
Hello Nigel. Hope all is with you and Bev.
Bob and Nancy
