Old 03-29-2015, 06:31 AM   #1
no electric in rv
2002 Forest River RV
we had electric one day, the next we didn't whether we plugged in or used generator.
we had a space heater plugged in and i think it blew a fuse? by the bed, one of the 30 amp fuses was off - i turned it back on, but no electric
(I am not sure this fuse feels right - it seems a little "loose")
I cannot turn that GF thing on in the bathroom like I used to.
I was told to check the "inverter switch" - but I don't know where the inverter switch is? can anyone tell me where the inverter switch is on a 2002 forest river?
milkpitcher is offline   Reply With Quote
Old 03-29-2015, 06:50 AM   #2
Ford Idaho's Avatar
What is the model number of this 2002?
Old 03-29-2015, 06:53 AM   #3
kc8lvy's Avatar
I think you mean your breaker not fuse. Flip the breaker to the off position then flip it back on. When a breaker trips sometimes the only way to reset it to flip it all the off then back on.
2004 Dodge Ram 2500HD Cummins
2017 Keystone Montana 3820 FK
2009 Harley Davidson Ultra Glide
kc8lvy is online now   Reply With Quote
Old 03-29-2015, 06:55 AM   #4
this is from title - would this be model? gta303w
Old 03-29-2015, 07:01 AM   #5
Oakman's Avatar
Welcome to the Forum. It helps when you ask questions if you tell us what you own (pop up, fifth wheel, class A motorhome, etc.) and the brand such as Cardinal, Sunseeker, Wildwood, Sanibel, Berkshire, etc.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 03-29-2015, 07:07 AM   #6
ok - this is a class a georgetown forest river
Old 03-29-2015, 08:01 AM   #7
fonzie's Avatar
First check your all your breakers into your AC panel, turn them off to reset then back on. Next if still no power, check to see if you have an auto-transfer switch, usually where your shore power come in the coach, might be damaged.
Name:	Georgetown breaker panel.jpg
ID:	72423   Click image for larger version
Name:	transfer switch automatic.jpg
Fonzie
Old 03-29-2015, 03:48 PM   #8
Send a message via MSN to Tiggerdad
Breaker should not feel "Loose" when on or off. When it is "loose" it is usually tripped. To reset it must be turned all the way off first and then back on. It should be a little "stiif" when turning on or off.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
electric
