Old 12-03-2018, 11:43 AM   #1
No flame
The stove has worked fine in our 2014 Mirada until two weeks ago. Now two burners won't light. Can I do anything, or should I just call a repairman?
MargiLou is offline   Reply With Quote
Old 12-03-2018, 11:56 AM   #2
got
gas ? the propane kind
MR.M is offline   Reply With Quote
Old 12-03-2018, 12:25 PM   #3
3/4 of a tank of propane. Also "got" milk, LOL ��
Old 12-03-2018, 12:45 PM   #4
Well gotta start somewhere . other gas appliances working ? more then 2 burners and one maybe works ?
Old 12-03-2018, 12:51 PM   #5
jeff64's Avatar
will it light off of a match?
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
jeff64 is online now   Reply With Quote
Old 12-03-2018, 12:58 PM   #6
Thumbs up
There are 3 burners - one front center, then back left and back right. The back right works. The igniter clicks when trying to light the other two and I can smell propane. I just tried a match, but it still doesn't light.
Thanks a bunch for the help. 🤠👍
Old 12-03-2018, 04:29 PM   #7
Interesting that a match won't light them if you can smell LP. Can you hear the burners "hiss"? You might listen to the good one for comparison. Then I would clean the burners because food can block the little ports. I am surprised that all the ports might be blocked on 2 burners though.
2011 Sabre Silhouette 260BHS
2006 F-250 6.OL
tinkerreknit is offline   Reply With Quote
Old 12-03-2018, 04:39 PM   #8
Brother Les's Avatar
No need to call a repairman. Lift the lid of the stove and get to the burners underneath. Clean gas tubes. If the 'tubes' are clogged (spider webs, bugs, soot, food debris, ect) and propane is backing up and leaking into the area, you very well may have some type of explosion (not good). Stop with the open flames until you check the tubing for being clogged.
Brother Les
Old 12-03-2018, 04:44 PM   #9
There was a report on here a couple of weeks ago of a stove exploding.
If you hear/smell gas and the burners won't light, you need to get someone with experience looking at it.
From our vantage point, us internet repairmen are only guessing. We might suggest things we'd do because our experience level make us comfortable doing so but we have no clue of yours. Don't get hurt trying things you are unsure about.
Days Camped: '16=46 '17=30 '18=51 '19=18
Old 12-03-2018, 04:57 PM   #10
One burner lights....
Propane getting to one burner.
two burners do not light.
Propane not getting to two burners.
Lift lid.
check for blockage at the gas/air mixing area of tubes.
Easy to look at and take apart.
Know what you took off and where it goes back on.
I asked my wife and she said that I could look at my stove (and fix it).
Ok... I did not ask my wife... she just said Fix the Dang stove or she will buy a new camper.... spider web 'nest' cocoon... wife does not get new camper.
So.... don't look at it and buy a new camper....
Brother Les
