Old 08-22-2010, 08:39 AM   #1
Jamboree Player
Unhappy no lights, no fridge
This rockwood 8283 fiver works awesome, with shore power - I have no power to the frig controls or anything else when I unplug therefore cannot start the frig on gas for travel ..... any ides why guys and gals?
tcalhoun777 is offline   Reply With Quote
Old 08-22-2010, 08:54 AM   #2
Iggy's Avatar
You MUST have 12 volt Battery voltage for all to work on propane gas.
Is the propane bottles full and on the correct bottle using the propane regulator?
Also is your Propane Gas detector powered up? Green light.
If not it will not allow the use of propane on any appliance.
2012 Georgetown XL - 378TS
Old 08-22-2010, 08:57 AM   #3
milzat's Avatar
Check the fuses on the 12 volt side of the converter.
Also, the MAIN breaker, on the left side(top, red arrow) of the converter.
milzat is offline   Reply With Quote
Old 08-22-2010, 08:58 AM   #4
Jamboree Player
yes sir, and I assumed it worked because when I plug shore power, the fridge works fine through this outlet along with everything else...... its seeming that the 12 volt battery is not distributing through the fuse/breaker panel ..... maybe a bad converter/ inverter? I am totally new to this and am running out of ideas fast .....
Old 08-22-2010, 09:00 AM   #5
Jamboree Player
did that yesterday - aok .....
I'm at the point where I may remove the panel and see how the 12v connection to the back might look .... and try to trace it back to the battery looking for inline fuses
Old 08-22-2010, 09:01 AM   #6
Iggy's Avatar
If you have shore power that will make the convertor produce 12 VDC to the system but it doesn't mean your battery is good.
Old 08-22-2010, 09:03 AM   #7
Iggy's Avatar
Does any of your 12 volt lights work without shore power?
I would first check the voltage and connections at the battery.
Old 08-22-2010, 09:03 AM   #8
milzat's Avatar
It's a Converter.
Check the BROWN 40 amp fuses also.
To do further investigating, you'll need a multi-meter.
Old 08-22-2010, 09:04 AM   #9
Jamboree Player
ah yes ... I follow you ..... the jacks and slide out work fine off the battery, its just the frig and interior that I have nothing ..... there's no power to the frig on battery and therefore it won't send the auto signal to go to gas frig ..... propane is all fine
Old 08-22-2010, 09:05 AM   #10
Jamboree Player
by the way it's great that you experienced guys are here helping out
