Old 08-31-2015, 06:56 AM   #1
No power
Ok so when I am plugged in at home all,of a sudden I have no power to the slide out the awning and the lights something has drained my battery BUT the microwave works and has power. I have checked all the fuses etc no problems.
When I plug it into the truck everything works just fine also I have checked the electrical cord etc everything seems fine. Does anyone have an idea what's going on? Thanks
VT Skier is offline   Reply With Quote
Old 08-31-2015, 06:58 AM   #2
Engineer of Crazy Train
ChooChooMan74's Avatar
Converter issue. Converter could be dead or Tripped circuit breaker.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 08-31-2015, 07:02 AM   #3
By chance is the breaker in the same place as the rest , because I checked all those and nothing was tripped.
Old 08-31-2015, 07:12 AM   #4
Flybob's Avatar
Check two high current in the converter. 30-40A. Usually orange /brown.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-31-2015, 07:19 AM   #5
Checked all the fuses but will check again what really confuses me is why when plugged into the truck everything works.
Old 08-31-2015, 07:23 AM   #6
clr
It sounds like your converter is not producing any 12 V DC. Check the high power fuses in the converter/fuse box. When you are plugged into the truck your truck is providing the 12v dc to the RV via the cord plugged into the Truck.
clr is offline   Reply With Quote
Old 08-31-2015, 07:40 AM   #7
TURBS's Avatar
Current limiting curcuit breaker should be checked by the battery as well.
More often then not they are resetable.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
power
