Old 12-13-2015, 02:21 PM   #11
RSchleder's Avatar
Is your stove lighting like it should? This proves there's actually propane available!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 12-13-2015, 02:22 PM   #12
Yes. The stove has been our way of heating the trailer up a bit
Jacquez707
Jacquez707 is offline   Reply With Quote
Old 12-13-2015, 02:24 PM   #13
RSchleder's Avatar
The blower should actually come on for several seconds BEFORE you hear any clicking noise. This clears the combustion chamber ahead of the gas valve opening up to ensure you don't have too much gag in the chamber causing a explosion. Is this happening?
Blower comes on FIRST, before ANY CLICKING!
30 years RV'ing
11 different RV's
Old 12-13-2015, 02:26 PM   #14
RSchleder's Avatar
Be sure to crack a window or two if your heating with your cook stove. Carbon monoxide!!!
30 years RV'ing
11 different RV's
Old 12-13-2015, 02:26 PM   #15
No explosions or anything. Blower doesn't come on so I assume it never ignites
Jacquez707
Old 12-13-2015, 02:28 PM   #16
Rupkin2's Avatar
Propane tanks full and on. It's the fan/blower that doesn't come on. You can hear a click like it's trying to send power to the unit but Johnny comes on. Was working fine a couple days ago just stopped on its own
For the most part I can only help for the easy stuff....lol
Once again locate the fuse/breaker.
From my understanding if the fan does not work the furnace will not kick in. This is a safety feature.
Not sure if this will help but when the weather was on the cool side there were a few times my propane would not run properly hence no heat. Just for shits and giggles see if the flame(s) on the stove are weak.
If so what I ended up doing was using the BBQ tank. Ya I dunno but it worked.
Other than the fuse/breaker check the obvious, see what the thermostat is set to and set to heat.
John
07- Classic 2500 LT CC 4x4 SB Duramax/Ally
13-320RLT Crusader TE
Reese 16K Kwik Slide/Prodigy brake contoller
Rupkin2 is offline   Reply With Quote
Old 12-13-2015, 02:29 PM   #17
RSchleder's Avatar
An electric space heater is ALWAYS a good addition to any RV, just for situations like your experiencing. Works well in cool weather, will be a bit lacking in cold temps though.
30 years RV'ing
11 different RV's
Old 12-13-2015, 02:33 PM   #18
RSchleder's Avatar
So, if the furnace is clicking, it's getting 12V. However, It shouldn't click if the blower has not been on for several seconds FIRST as I stated above.
30 years RV'ing
11 different RV's
Old 12-13-2015, 02:45 PM   #19
RSchleder's Avatar
Just need a bit more info--is the thermostat clicking or is it the furnace clicking?
30 years RV'ing
11 different RV's
Old 12-13-2015, 02:47 PM   #20
Sounds like a click from the blower trying to start. But doesn't
Jacquez707
power
