Originally Posted by Jacquez707
Hey everyone
Trying to figure out why when I turn off the generate I no longer have any power or lights. Nothing in trailer works, not heater, fridge, hot water heater, lights or anything. I bough new batteries and still nothing. Check all fuses and control panel and everything looks fine. I own a 2009 Forest River Cardinal 35SBQLE (35LE?)
I also started having issues with heater when generator is on. You can flip to heat and hear a click but it doesn't come on. HELP PLEASE any info or where I should start will be greatly appreciated
Start
Thermostat Calls
for Heat
The wall thermostat controls the operation of the furnace by reacting to room
temperature, this allows current to flow through the On/Off switch to the module board.
The module board constantly checks for a minimum 9.5 volts. If there is not 9.5 volts,
the module board will go into a stand by mode until adequate power is supplied. It will
then resume normal operation.
Upon a call from the thermostat, the module board thermostat circuit will go active. The
sail switch circuit is verified as being open. The blower output is energized. Blower
motor starts.
15 Seconds Purge
Cycle
The module board will then verify that the sail switch circuit is closed and motor is up
to speed. If this circuit remains open for 30 seconds after the blower motor starts, the
module board will go into lock out and shut down the blower motor.
The module board checks that the gas valve relay contacts (which are located on the
module board) are open before the ignition sequence starts.
The board has a pre-purge timing circuit of (approximately 15 seconds). This allows the
chamber to purge.
7 Seconds Ignition
Cycle and Flame
Sense
The module board will energize the gas valve and enable the high voltage spark output
to the electrode for 7 seconds of ignition time.
The module board will then check for flame sense to verify successful lighting of the
main burner flame. Sparking will then be terminated and the gas valve and blower
outputs will remain energized.
If ignition is successful the module board will monitor the flame sense, sail switch and
limit switch circuits, and the thermostat inputs during the heating period.
The flame is sensed through the spark wire and electrode. Therefore, it is essential that
the electrode is properly positioned in the burner flame.
Hi I copied the above description of operation from the library. It sounds like the module board is going into a stand by mode not letting the furnace system to start. The furnace should shut down and lock out after 30 seconds.
Hope this helps Tim
