Old 12-14-2015, 12:55 AM   #31
ramair's Avatar
The board is located inside the heater unit, mine went bad and had it replaced, it does sound like that is the issue.
Andrew & Donna Reyes
2012 Georgetown 378XL
2015 Ford Taurus
Our Baby Dachshund
Cammie
ramair is offline   Reply With Quote
Old 12-14-2015, 01:03 AM   #32
Is it a DIY fix? Cuz mine isn't able to be moved at the moment. We live in it while our house is being built. So I need to fix myself.
Jacquez707
Jacquez707 is offline   Reply With Quote
Old 12-14-2015, 06:33 AM   #33
RSchleder's Avatar
IF you can't get it fixed yourself, best bet might be to have a "mobile repair technician" come to your location to trouble shoot and repair your furnace. It can get expensive to start "shotgunning" parts and actually replacing good parts long before you find the culprit.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 12-14-2015, 07:05 AM   #34
Hi make sure the TT has a solid 12 volts! Furnace will not run if battery power falls below 9.5 volts to the module board. Is the TT plugged into a 110 volt ac power supply to charge the battery. The furnace is a big power hog and will suck the life out of a battery very quickly. If you have a solid 12 volts from the battery make sure the switch in the thermostat is making contact and supplying 12 volts to the furnace. The white wire on the back side of the thermostat should have 12 volts. It supply's the furnace module board 12 volts to start. If you have 12 volts there is 4 possible problems with the furnace not wanting to start.
1/ fuse blowen to the supply power to the furnace.
2/ You may have an higher end electronic thermostat and is it switch over to heat or the control module in the air conditioner has failed and not commanding the furnace to start.
3/ Sail switch to prove the fan blower is running and moving air is stuck in the closed position. This switch needs to be open no air flow to start the furnace. This is not a very common problem but can happen.
4/ The module board has failed in the furnace.
Hope this helps Tim
TimVWulp is offline   Reply With Quote
Old 12-14-2015, 12:07 PM   #35
To power blower directly, disconnect it from circuit board and connect to a " car battery ". This will tell you if the blower is working or not. It sounds like the relay for the blower is energizing, that is why I suspect the blower is faulty.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 12-20-2015, 07:06 PM   #36
Jhochst's Avatar
Did you get it fixed? Curious the problem
Jhochst is offline   Reply With Quote
Old 12-20-2015, 11:09 PM   #37
No gone for holidays will figure it out after new year. Will keep you all posted.
Jacquez707
Old 12-20-2015, 11:40 PM   #38
caper's Avatar
Go outside and turn fan motor 1/4 turn and try starting furnace again. Could be a dead spot on the motor. If the furnace does start you will need to replace the motor.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
power
