Old 12-13-2015, 02:41 PM   #1
No power
Hey everyone
Trying to figure out why when I turn off the generate I no longer have any power or lights. Nothing in trailer works, not heater, fridge, hot water heater, lights or anything. I bough new batteries and still nothing. Check all fuses and control panel and everything looks fine. I own a 2009 Forest River Cardinal 35SBQLE (35LE?)
I also started having issues with heater when generator is on. You can flip to heat and hear a click but it doesn't come on. HELP PLEASE any info or where I should start will be greatly appreciated
Jacquez707
Jacquez707 is offline   Reply With Quote
Old 12-13-2015, 02:48 PM   #2
nomad297's Avatar
Have you checked your battery disconnect?
Bruce
Old 12-13-2015, 02:52 PM   #3
Rupkin2's Avatar
not an expert but if all works with the genny then I would think maybe your batteries a weak, cables are loose on posts or possibly if there is a disconnect switch it is off.
Also I think there is a fuse on the positive wiring from the battery.
John
07- Classic 2500 LT CC 4x4 SB Duramax/Ally
13-320RLT Crusader TE
Reese 16K Kwik Slide/Prodigy brake contoller
Rupkin2 is offline   Reply With Quote
Old 12-13-2015, 02:54 PM   #4
I changed the batteries so brand new. Cables are good will look for a battery disconnect
Jacquez707
Old 12-13-2015, 02:58 PM   #5
Found it and it had been disconnected! Now my issue is the heater to the trailer itself. You can hear it click but won't turn on
Jacquez707
Old 12-13-2015, 02:59 PM   #6
RSchleder's Avatar
Do you have a 12v disconnect switch? It could have been inadvertently turned to OFF.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 12-13-2015, 03:01 PM   #7
Rupkin2's Avatar
Were the batteries charged before you inserted them?
Follow the positive line I'm sure there is a fuse. It shouldn't be far from the batteries. Should be a little red rubber case.
John
Old 12-13-2015, 03:01 PM   #8
RSchleder's Avatar
Propane turned on?
Propane in tank? ( not empty)
30 years RV'ing
11 different RV's
Old 12-13-2015, 03:08 PM   #9
John
I figured out the battery disconnect and that was the issue. Might of been moved when wife put stuff under the trailer in storage compartment. Thank you John
Originally Posted by RSchleder View Post
Propane turned on?
Propane tanks full and on. It's the fan/blower that doesn't come on. You can hear a click like it's trying to send power to the unit but Johnny comes on. Was working fine a couple days ago just stopped on its own
Jacquez707
Old 12-13-2015, 03:17 PM   #10
RSchleder's Avatar
Have you pulled the outside panel off and had your wife turn on the furnace? Might be able to see what is or is not happening. Also, is there a reset button on your furnace that you can see while you have the panel off?
What does your furnace owners manual say in the "trouble shooting" section?
30 years RV'ing
11 different RV's
power
