Old 07-07-2012, 08:48 PM   #11
rbq
Follow the two red wires that run from the power block in the back of the fridge. The red wire that goes to the right goes over to the flue on the refrigerator. Between the two wires there is a small resetable circuit breaker. Press between the two wires with your little finger. If it click you have found the problem. Go in & check to see if you have lights on the control board above the fridge. You should also have lights on in the fridge now. This circuit breaker protects the fridge for overheating, especially if it is out of level for long.
rbq is offline   Reply With Quote
Old 07-07-2012, 10:19 PM   #12
We tried that. Well we followed the one to the right and it met up with another red wire. Pushed the button between it but it did nothing. We don't have any power or gas to it yet and no lights on.
Kuntz is offline   Reply With Quote
Old 07-07-2012, 10:21 PM   #13
It has been hot here for a few days so perhaps it kicked it out. But our camper is level and has been running for 3 weeks
