Old 07-06-2012, 07:14 PM   #1
No power or gas to fridge
We have a new sandpiper 365 and have absolutely no power or gas to our fridge. The plug in works (where the fridge is plugged in to). Help!
Kuntz is offline   Reply With Quote
Old 07-06-2012, 07:18 PM   #2
camper_Lucy's Avatar
the frig requires DC to power the control board, so do the camper lights work (they are DC)? are and red lights on in the fuse panel (DC side)? even if not check the auto style DC fuse for the frige maybe swap it with another one.
without the control board the GAS and AC will not work
Also press the battery level check button on the switch panel are all lights lit, or two, or one?
2011 GMC 3500HD 4x4 Crew DRW Duramax
Pullrite 20.5K
2012 Sierra 365SAQ
2006 Police Roadking FLHPi
camper_Lucy is offline   Reply With Quote
Old 07-06-2012, 07:37 PM   #3
Yup lights work. There are no lights on in the fuse panel. We are plugged in to a 50 amp site
Old 07-06-2012, 07:43 PM   #4
Sounds like you have DC power then, my unit is not here so I can not look at it to help, can you see the DC control panel wiring when you open the outside cover, if so I'd look to a lose connection? Did this work prior, at PDI, are the lights on above the frig door (orange) on the control panel?
Pullrite 20.5K
2012 Sierra 365SAQ
Old 07-06-2012, 07:47 PM   #5
Yeah it worked up until maybe a day ago. We have a seasonal site and showed up to stuff thawing. There are no lights on (not even the check light) and no lights on in the fridge. They have been tinkering with the outside wiring and haven't found anything.
Old 07-06-2012, 07:53 PM   #6
Sounds like it is something with the DC control panel, without that the gas will not fire on and the AC will not start, I do not know of a way to test or bypass it off the top of my head sorry.
Pullrite 20.5K
2012 Sierra 365SAQ
Old 07-06-2012, 07:56 PM   #7
onetonford's Avatar
In the back of the fridg is a plastic cover over the control board I think you remove cover by removing 1 screw and prying at two locations where it shows to put a scerw driver and under cover is a glass fuse for the 12 volts that they don't tell you about check and see if it blew......
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 07-06-2012, 08:02 PM   #8
Also go to this thread and post 2 from Herk has a troubleshooting doc that may help.How to tell fridge is running on electric? Other than the fact that it's cold!
Pullrite 20.5K
2012 Sierra 365SAQ
Old 07-06-2012, 10:41 PM   #9
He checked that fuse but doesn't know if it has blew. Thanks for all your help it is greatly appreciated! We will phone the dealership tomorrow.
Old 07-07-2012, 10:26 AM   #10
We tried a new circuit board and that didn't work.
