Old 04-30-2012, 10:15 AM   #1
no power to Concertone radio 2002 shamrock 16ft
I have a 2002 shamrock 16ft i have only one problem the radio has no power i have changed the fuse to be sure but still no power...
is there something else that has to be turned on to make it work...
we have no other issues to complain about,, just need my music to work also is there any special attachment i need to hook up my TV
we have a annttena on the roof so I would appricate any help here..I have check the owners manuals that we recieved when we purchase the trailer but they are no help.. Please help me .. we are p[lannin on making our 1st outting by the end of may
thank you
Tessio
tessval is offline   Reply With Quote
Old 04-30-2012, 10:20 AM   #2
Herk7769's Avatar
There might be an inline fuse located behind the unit.
HAM CALLSIGN - KC3FFW
Old 04-30-2012, 10:45 AM   #3
Triguy's Avatar
What radio do you have? That will help.
I assume by "fuse" you meant the fuse in the converter for the radio. That's the first thing to check so good for 'ya.
As Herk said, check the radio's fuse next. My Genesis (Concertone) has a glass cartridge fuse inline in the back of the radio wiring. Need to pull it out of the cabinetry.
As for the TV, is your 2002 Shamrock wired for TV (do you have a panel next to your radio for a TV to plug into or next to one of the beds) or are you trying to retrofit the unit? The model of the radio would help here, too.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-30-2012, 11:42 AM   #4
TURBS's Avatar
My newer concertone has two fuses located behind the unit.
So its fused 3 times ! Just an fyi
Old 04-30-2012, 04:56 PM   #5
the model is Concertone 2000 TV, and yes the fuse was in the inverter, i will try to unscrew it from it position and look for another fuse, just tell me what type of fuse this might be thank you all we are preparing for our 1st outing i want to be sure i know how all this stuff works.. next week end I will be un-winterizing her got any suggestion on this thanks you all tessi
Old 04-30-2012, 05:04 PM   #6
TURBS's Avatar
it really could be anything .
It would be best to take it apart and see .
your camper is 12 years old at this point and it might be sketchy on wether someone has the same unit as you let alone if they have ever replaced the fuse in the back if there is even one there .
good luck ~!
Old 04-30-2012, 05:17 PM   #7
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
BTW Even if you fix the power problem, your TV probably won't work unless you install a digital to analog converter.
dimurrrw is offline   Reply With Quote
Old 04-30-2012, 05:19 PM   #8
TURBS's Avatar
good catch its old enough not to be hd .
tv will work for dvds but thats it .
