Old 04-29-2015, 08:35 PM   #11
A small update:
Turns out the circuit breaker issue was user error- left it unhooked and reattached, self reset kicked in and no more issues. Confirmed both posts are getting the same voltage.
Using the multimeter inside the junction box I get 12V, but still no power inside at the converter. Tomorrow I might try removing the converter and try a few wires under the trailer. Here's a couple of images for reference, maybe something shown here will be useful.
Junction box (positive wire in blue cap tested good at 12V, which it should since it's only 6' past the circuit breaker)
And inside panel (0V at all 3 red, white and blue terminals)
voodoozen is offline   Reply With Quote
Old 04-30-2015, 05:37 AM   #12
WolfWhistle's Avatar
I can see a Red and White connected to the panel that isn't fused; what are they doing?
Second, in the J-Box it looks like all the White wires are wire-nutted together. This is a lot of wires in one wire nut, are you sure one or more wires are not open (broken off) in that busy wire nut?
Is the Battery (-) is connected to the frame?
Make sure your ground reference you are using for your meter at the panel is truly ground (-).
I would think at the upper RED lug there should be two cables, one from the Battery and the other to Converter.
As well, I think the WHITE lug (far right) should be (-) from Converter and one from the J-Box; to the frame; and all the (-) connnected in common?
You don't need to be concerned about the Converter. You know its working because it powers the lights when in shore power mode.
Your job is to get the battery voltage to the panel. Not to mention all grounding correct.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 04-30-2015, 10:28 AM   #13
WolfWhistle- thanks for the feedback, great insights, I really appreciate it! I'll try to respond best I can, bear with me as I'm not much of an electrician (aka not one at all), but I'll tackle these one at a time.
The red and white leads coming down behind the fuse board are both connected to the back of battery lead terminals and feed down into the converter relay. My understanding is that the relay should switch between 110V and 12V when shore power is disconnected, but since I don't have power at the terminals now, I don't think the relay is the culprit. But I could be wrong...
There's only one white wire coming into the back of the upper panel (save the one going behind it down to the converter), it looks to me as though all the white (-) wiring is tied together at the junction box, which sounds like it may be part of my issue.
Good question, I'll have to take a look later this evening. My first thought when I opened the box was "Are these really all supposed to be connected?", it seems like an awful lot of wiring to be coming together to my self-admittedly untrained eye.
Battery ground looks good, I took a wire brush to the frame, screw and ring terminal just to be sure they were cleaned and had good contact. It also holds the breakaway switch mounting bracket, (which I haven't tested but need to), which I also cleaned, just in case. I was using that ring terminal as my ground when I checked the positive lead in the picture- should I maybe look for another ground?
Glad to hear that. Most of my camp time will be on shore power, last thing I want is to find out I have no power too late to work on it and keep things running.
Old 04-30-2015, 12:05 PM   #14
To make the job of the converter and the distribution panel clearer... Its dual purpose; having circuit breakers for 110vac (with shore power only if you don't have a Genny) and fuses for those 12vdc devices. It also houses the converter which makes. 12vdc our of 110vac. Without shore power .. you only have 12 volts to the fuses coming from the battery... No hundred 110 volt ac at all.... The only things that will work are those appliances or lights that are powered by 12 volts by the battery through those fuses. When you have shore power... AC powers all the AC devices through the circuit breakers as well as it powers the converter that supplies 12 volts DC again through the fuses to the 12 volt devices. Typically the converter also charges your batteries that's why the 12vdc from the converter and the 12 volts from the battery are on the same terminals.
Old 04-30-2015, 12:18 PM   #15
The (-) battery to the frame would not be used for anything else
If it were me.
Old 04-30-2015, 12:19 PM   #16
I'm still not clear why wires are connected to the fuse panel but not fused
Old 04-30-2015, 12:19 PM   #17
TURBS's Avatar
Which ones?
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-30-2015, 02:13 PM   #18
here's a picture of the back of the panel (not my picture, but it's what my fuse panel looks like):
They feed down into the black relay you can just make out in the bottom center of that picture
Any advice on where to ground when testing the wiring in the junction box?
Old 04-30-2015, 02:17 PM   #19
Evereddie's Avatar
That's the 12volt input to the panel. Come from output of converter and battery but it's the battery connection to this that is apparently not working.
Evereddie is offline   Reply With Quote
Old 04-30-2015, 05:46 PM   #20
I see it now... had to save the picture and zoom in... the Red and White just passes by what I thought were connections, but are in fact connected at the rear. I haven't see a panel like this. The heavy lugs seem to be common and pass from rear of the panel to the rear. Sorry to chase this rabbit.
I don't see why using the frame of the panel or a white wire (-) would be a problem for reference ground for your meter.
Now, to recap; you have +12 on the load side of the CB, but you don't have +12 at any wire in the distribution panel. Then there is an open between the two points. I would look for a battery cut off switch or another J-Box. If there isn't any of these to be found, I would run new wiring from the Battery. Probably a #8AWG or better.
battery, power
