Old 05-04-2015, 08:21 AM   #31
mrmichael's Avatar
another thought
Could the two empty fuse holders be "reverse polarity" fuse positions? I would think if they were missing there would be no power to converter ?
Other Motorhome
2013 F-150 Eco-Boost V6
mrmichael is offline   Reply With Quote
Old 05-04-2015, 11:55 AM   #32
fonzie's Avatar
Yes that could be for the reversing fuses.......
Fonzie
Old 05-04-2015, 03:02 PM   #33
I'm unfamiliar with reversing fuses - can I put a couple 15 amp fuses in there to test it, or is that going to potentially cause an issue?
voodoozen is offline   Reply With Quote
Old 05-04-2015, 03:03 PM   #34
TURBS's Avatar
I'd put the fuses in @ worse they will just blow.
Maybe put in 10's
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "4 nights"
Old 05-04-2015, 03:18 PM   #35
Evereddie's Avatar
The empty fuse holders look like they are for other devices that are not installed in this camper, therefore no fuse. The empty terminal lug under each one is the give away. Those positions are also blank on the fuse chart but can't see enough detail to see what it says on there.
Evereddie is offline   Reply With Quote
Old 05-04-2015, 03:24 PM   #36
Looking at it now, it says:
1) 15 Porch
2) | Kit
3) | Bath
4) | Furn & Refer
5) | Living
1 Acc) 7.5 Radio
Old 05-04-2015, 03:29 PM   #37
mrmichael's Avatar
fuses
There are (in most I've seen) two (usually 40a) fuses to protect the camper if the battery is hooked up backwards. Hard to see in the pictures but couldn't hurt anything to put a fuse in those holders to see if there is any change. The wires going to those fuse positions look larger than the ones going to the other fuses?
Other Motorhome
Old 05-04-2015, 03:30 PM   #38
TURBS's Avatar
Here's how mine are.
Four on lower left
TURBS
Old 05-04-2015, 03:30 PM   #39
jk510's Avatar
Stop worrying about the converter. That can only confuse things. We know that's okay and all the wiring from to breaker/fuse panel because it all works when you're plugged in to shore power. You need to trace the wire back from where it connects to the wire from the converter 12v line to your battery. There's a break somewhere along there.
Joel K
Southeast AZ
2013 Coachman Mirada 29DSSE
jk510 is offline   Reply With Quote
Old 05-04-2015, 04:33 PM   #40
Sound advice. I think I'll swing into an auto parts store on the way home and grab some 6AWG wire. At this point spending this weekend pulling wires is the easiest option. I removed the converter and took a look behind it where the wiring comes into the trailer, it all looks intact, but who knows what is unseen.
If I get lucky maybe I'll discover a previously unknown in-line fuse, or some other easy fix
battery, power
