Old 03-18-2012, 04:20 PM   #11
pwrboatfan's Avatar
This is what is on the back o the wall plate
2006 Salem 392FKTB PT
Seasonal Camping at Pomme De Terre Lake in MO
pwrboatfan is offline   Reply With Quote
Old 03-18-2012, 04:25 PM   #12
pwrboatfan's Avatar
Originally Posted by capucine
Have you checked the coax connection on the roof at the antenna plug in. It is very possible also that your booster is bad. Without the booster you will get hardly nothing.
I checked the connection at the base (it was the only thing I could get to on the ladder). The base coax was tight.
Old 03-18-2012, 05:15 PM   #13
Malco's Avatar
Our tv in our old trailer would lose reception sometimes.It had a booster with an on/off switch that slid up and down.If I wiggled the switch a little it would start to work.Eventually I replaced it with a new switch that had a push button on/off switch and was still working when we sold the trailer.
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
1968 Pontiac Le Mans
Malco is offline   Reply With Quote
Old 03-21-2012, 09:48 PM   #14
pwrboatfan's Avatar
Quick question, I was at my local RV dealer and he told me my booster is at that wall plate? Isn't it in the head of the Antenna? See above photo of wall plate.
Old 03-22-2012, 07:04 AM   #15
this is your booster at the wall plate. If you look at this plate there is a small button to turn on your booster. Also a small green light comes on when you push on this mini button. My wall plate booster is brown. As I can see yours is white.
capucine is offline   Reply With Quote
Old 03-22-2012, 07:13 AM   #16
Herk7769's Avatar
We get this question all the time.
The wall plate actually serves several purposes at the same time.
1) It is a switch that switches reception from the roof antenna to the external campground cable connection. (Green light "ON" roof; Green light "OFF" outside cable."
2) It provides 12VDC power to the rooftop antenna to power the amplifier in the antenna head.
3) Your model plate uses an external splitter that routes signal (far cable in your photo) to the faceplate coax connector and the "house" coax run (there may be an additional splitter for multiple rooms).
HAM CALLSIGN - KC3FFW
Old 03-22-2012, 08:10 AM   #17
pwrboatfan's Avatar
Thanks Herrk for your response. My park model is wired for both Cable and Satellite. On the wall plate the top coax is for Sat. and the bottom is for TV/Cable. I was reading Wingard's trouble shooting guide and it said to check for 12vdc at the head on the roof. If there is power there, then it is a bad antenna head. My question is it looks like just coax at the entrance into the head on mine. Does the coax carry the 12vdc?
Old 03-22-2012, 08:26 AM   #18
Herk7769's Avatar
Yes. The coax carries the 12VDC to up to the head concurrently with the RF TV signal coming down from the head. The TV signal is like alternating current so it does not interfere in any way with the DC; you can think of it as the TV signal "riding" on the 12 volt power.
To check for 12 VDC at the head (I assume you checked that the green light on the wall plate is on) just remove the coax from the antenna head and put the red lead of the meter on the center copper wire and the black lead of the tester on the shield (part with the threads). It should read 12-14 volts DC.
Old 03-22-2012, 08:38 AM   #19
pwrboatfan's Avatar
Sounds easy enough! I will be back down at the camper on Saturday and will check it. Yes, the green light is on. I just find it hard to believe the head is bad, but maybe it shorted out, who knows! The camper I had before this one was a 1997 and it worked great till the day the camper was gone.
Old 03-22-2012, 08:46 AM   #20
Herk7769's Avatar
If water gets in there with power on it can raise all kinds of havoc with the amp.
On a side note: How is the over the air reception where you are?
Is it possible there are NO stations to receive?
Remember that all most all TV broadcasts are now DIGITAL. If you have an older TV (NOT digital) you will NEVER receive a TV signal. You MUST have a digital to analog converter box to watch over the air TV now (in both Canada and the US).
Also Digital TV uses "primarily" UHF, BUT there are digital VHF stations as well. Digital VHF stations are directional. Aiming the antenna is critical to good (or sometimes any) reception.
Some great threads on the subject:
Winegard wingman antenna booster
antenna reception
Digital TV confusion
Use this web site to find the POSSIBLE broadcast towers in your area and the direction to aim your antenna here: http://www.antennaweb.org/
Name:	913th 3rd Annual Picnic and Camper photos 036.jpg
File Type: pdf Protractor used to align TV antenna.pdf (219.7 KB, 15 views)
