Old 05-10-2015, 07:13 PM   #1
No satellite connection in 2015 Salem Villa Estates
Just purchased new Salem Villa Estates and set on permanent site. Ready to set up satellite but could not get it to work. Called dealer and was told the bedroom has the 2 connection, antenna and satellite but living room only has antenna connection box. Anyone else having this issue, ideas how to resolve?
2Bretired is offline   Reply With Quote
Old 05-18-2015, 01:04 PM   #2
I am an electrican. I added a new wire from the outside connection point to the master bed. I am sure a good local electrician could add a wire for you.
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 05-18-2015, 01:44 PM   #3
bubbles's Avatar
Hard to believe the living room cannot get cable input. Connect ant to park cable input and connect other end to receiver and from receiver to tv and see if that will work.
Old 11-15-2015, 08:08 PM   #4
gne
got a reply back from forest river on same issue with mine. cable runs to bed room and then straight to entertainment center in living room. all connections are there.
gne
gne is offline   Reply With Quote
Old 11-30-2015, 06:53 PM   #5
Satellite TV like direct tv and dish can not have a splitter in it. I had to remove my splitter to get my Direct TV to work. So I only get tv in my living room on my 2016 26DBH Grey Wolf.
hotheadbilly is offline   Reply With Quote
Old 12-01-2015, 06:42 AM   #6
Thanks everyone for the great ideas, I also got reply back from FR about this issue, once it warms up in the spring I will check out all the ideas. For now, I guess I am up north shoveling snow for another season!
salem, satellite
