Old 05-14-2012, 04:00 PM   #1
pchrcane65's Avatar
No tv channels on brand new Patriot
Hello I am new to this forum my problems is we just bought a new 2012 forrest river patriot edition and while at dealership the tv had channels galore we get it home and cannot pick up a single one. Booster is on, checked connections, ran memory channel, everything I can think of and still nothing I can watch dvds works fine. Any ideas would be greatly appreciated Thanks
pchrcane65 is offline   Reply With Quote
Old 05-14-2012, 04:07 PM   #2
Herk7769's Avatar
You will need to switch the TV's "input" to tuner.
The DVD's play might be playing on the "composite" input.
I assume the antenna is raised as well and aimed at the TV towers?
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 05-14-2012, 04:11 PM   #3
trudinator's Avatar
And you did a scan for channels?
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 05-15-2012, 07:41 AM   #4
pchrcane65's Avatar
Herk7769 it is a wineguard rs 1500 it does not raise as far as I know it is pretty much stationary and to switch the TV tuner would be where in the tv programming?
Trudinator yes I did a channel scan and came up with nothing.
Old 05-15-2012, 07:51 AM   #5
TURBS's Avatar
Booster on?
Old 05-15-2012, 07:54 AM   #6
pchrcane65's Avatar
Yes booster is on the only thing I havent check for connection is on the atenna itself. Dealership serviceman told me on phone it was my TV untill I told him you can watch DVD's so then he says its a loose connection.
Old 05-15-2012, 09:19 AM   #7
Herk7769's Avatar
The remote for the TV has an "input" button.
Press it repeatedly until "tuner" appears.
You can not do a channel search from the menu unless tuner is selected on the TV.
There is also a remote (pardon the unintentional pun) possibility that the cables are bad. The crimps on the F-Connectors in the wall and on the roof might be no good.
Old 05-15-2012, 09:37 AM   #8
pchrcane65's Avatar
Thanx herk7769 I will try this.
Old 05-15-2012, 09:43 AM   #9
Herk7769's Avatar
Here is the manual for the booster box.
Looking at the back in your hand, the lower left cable is the one that goes to the roof.
Old 05-15-2012, 06:03 PM   #10
pchrcane65's Avatar
Herk I pulled the atenna up and found a big cut in the coax cable bout 6 inches from end this probably is problem. How bad you think its to replace? Is their a certain coax to be ran ??
Old 05-15-2012, 07:02 PM   #11
Herk7769's Avatar
Well that certainly will do it. Make sure the power is off to the antenna boost as 12VDC coexists on that wire with the TV signal.
Are you familiar with coax repairs and have the tools?
Cable TV Coax Cable Repair Kit 092-499
I would cut the coax below the bad spot and put an F connector on it. Then I would buy a short 12 inch or however long you needed already made coax jumper cable and a coax female to female union. Once you have all your stations coming in; I would wrap it with splicing tape (a self bonding rubber tape that is waterproof).
Old 05-15-2012, 07:39 PM   #12
pchrcane65's Avatar
Thanks alot Herk I will try to repair tomorrow. I will keep u posted u have been great help.Thanks again.
led pad
