Old 05-14-2012, 04:00 PM   #1
pchrcane65's Avatar
No tv channels on brand new Patriot
Hello I am new to this forum my problems is we just bought a new 2012 forrest river patriot edition and while at dealership the tv had channels galore we get it home and cannot pick up a single one. Booster is on, checked connections, ran memory channel, everything I can think of and still nothing I can watch dvds works fine. Any ideas would be greatly appreciated Thanks
pchrcane65 is offline   Reply With Quote
Old 05-14-2012, 04:07 PM   #2
Herk7769's Avatar
You will need to switch the TV's "input" to tuner.
The DVD's play might be playing on the "composite" input.
I assume the antenna is raised as well and aimed at the TV towers?
HAM CALLSIGN - KC3FFW
Old 05-14-2012, 04:11 PM   #3
trudinator's Avatar
And you did a scan for channels?
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 05-15-2012, 07:41 AM   #4
pchrcane65's Avatar
Herk7769 it is a wineguard rs 1500 it does not raise as far as I know it is pretty much stationary and to switch the TV tuner would be where in the tv programming?
Trudinator yes I did a channel scan and came up with nothing.
Old 05-15-2012, 07:51 AM   #5
TURBS's Avatar
Booster on?
Old 05-15-2012, 07:54 AM   #6
pchrcane65's Avatar
Yes booster is on the only thing I havent check for connection is on the atenna itself. Dealership serviceman told me on phone it was my TV untill I told him you can watch DVD's so then he says its a loose connection.
Old 05-15-2012, 09:19 AM   #7
Herk7769's Avatar
The remote for the TV has an "input" button.
Press it repeatedly until "tuner" appears.
You can not do a channel search from the menu unless tuner is selected on the TV.
There is also a remote (pardon the unintentional pun) possibility that the cables are bad. The crimps on the F-Connectors in the wall and on the roof might be no good.
Old 05-15-2012, 09:37 AM   #8
pchrcane65's Avatar
Thanx herk7769 I will try this.
Old 05-15-2012, 09:43 AM   #9
Herk7769's Avatar
Here is the manual for the booster box.
Looking at the back in your hand, the lower left cable is the one that goes to the roof.
Old 05-15-2012, 06:03 PM   #10
pchrcane65's Avatar
Herk I pulled the atenna up and found a big cut in the coax cable bout 6 inches from end this probably is problem. How bad you think its to replace? Is their a certain coax to be ran ??
led pad
