Old 06-18-2019, 09:50 PM   #1
No TV reception
Unable to tune in any local TV broadcasts. Tried to scan local stations, received none. Any ideas... Thanks
SunSetOnTwilghtLn is offline   Reply With Quote
Old 06-18-2019, 09:56 PM   #2
Depends .... Usually you have a button on the plate where your tv antenna is plugged in. Pressing it will change from cable to over the air. Some have a separate button to turn on the antenna.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 06-19-2019, 12:54 AM   #3
bikendan's Avatar
Please post what Brand your RV is and what year because you didn't list it in your profile.
FR makes nearly 100 different brands and many share the same model number.
Old 06-19-2019, 05:04 AM   #4
in a lot of cases it isn't the antenna or the RV, check your setting within your television. make sure it's set to the input source to scan for over the air signals. All TV's are different... Poke around in your settings menu
greggcowan is offline   Reply With Quote
Old 06-19-2019, 08:00 AM   #5
Look to see what direction other campers have their antenna pointed before you do the scan. This might help you zero in on the strongest signals.
Old 06-20-2019, 08:24 PM   #6
No TV reception
2018 287 BHS trying different things with no luck. I am getting power to the booster, still no reception. Tried a different TV still no luck. Looking for ideas. Thank you.
Old 06-20-2019, 08:55 PM   #7
BandJCarm's Avatar
There are places I have camped that have zero OTA channel reception...........
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 06-20-2019, 09:34 PM   #8
rk06382's Avatar
There are places I have camped that have zero Cell phone reception.
We keep a binder of DVDs to play on the TV.
Robert
2018 FR3 28DS | Boondock 99% of the time
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings | Koni Shocks | RVLock
Solar Power & Battle Born batteries
rk06382 is offline   Reply With Quote
Old 06-20-2019, 09:38 PM   #9
I find that the AntennaPoint app to be useful.
I wished I’d gone camping sooner in life.
Traveling Circus is offline   Reply With Quote
reception, tv reception
