Have you selected the input type in your tv's menu? After selecting the input type you will have to do a channel scan on your tv when using a campgrounds cable connection. If you have a cable input on the outside of your trailer it will only work when the power button for the over-the-air booster is off. Some campgrounds may have the type of cable service where you need to rent a converter from them.
If you have a satellite input on the outside of your trailer it only connects to the satellite output at the main tv. It is a straight run coax without a splitter for another tv. You will need to set up your satellite dish and receiver. You will also need to select the input connection that your satellite is connected to in your tv's menu.
To use your roof top over-the-air (OTA) antenna you will have to turn on the antenna's booster which is a little button on the faceplate, select OTA in the tv's menu and run a channel scan. When the little light is on, the booster is on, if the light is off, the booster is off and the cable connection is passed through.
Richard & Jill
