Old 07-24-2015, 04:41 PM   #1
No TV Signal
Just brought my Forester home from storage after a month to prep for a weekend trip. Tried to turn on one of the TVs while I was cleaning the interior and the message on the screen kept saying to "run auto scan." I did it five times and then checked the other TV. Same thing. Went up on the roof and the antenna looks fine. Last time I had it at me house I pick up tons of channels over the air. This time...zero. Any advice??
steveadamcik is offline   Reply With Quote
Old 07-24-2015, 05:24 PM   #2
Did you have your antenna amp button on?
Jerry. Vietnam vet.
Retired
jgahlhoff is offline   Reply With Quote
Old 07-24-2015, 05:26 PM   #3
Also is is set for Air not cable
Jerry. Vietnam vet.
Retired
Old 07-24-2015, 05:30 PM   #4
Sounds a lot like the amplifier is off -----
bruceatlam is offline   Reply With Quote
Old 07-24-2015, 06:01 PM   #5
Same type of problem - except the front TV works fine on the park cable, but can't get bedroom TV to pick up anything! I ran the scan several times. Can't find any switch to br TV. Any ideas? Thanks.
2014 Sunseeker
3170ds (Suzuki Samurai 1986 toad)
Gary and Dottie, fur babies Doodle(corgi) and Beau(yellow lab)
Yorkranchgalnguy is offline   Reply With Quote
Old 07-24-2015, 06:08 PM   #6
Georgia Frog Rally 2018
aceinspp's Avatar
Yorkranchgalnguy: make sure the bed room Tv is set to cable and scan, also you may have two connections by the tv in the bed room as we do one is for cable/aant the other is for satellite. Make sure it is connected to right outlet. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 07-24-2015, 11:40 PM   #7
Only one hook up. Checked connections :tight . TV says cable. Ran scan many times- no joy. Living room TV great so cable hook up good. There must be some trick or it's just not wired right. I got air channels fine in Boise, so it's wired to antennae okay. This is the first time I bought cable. I'm stumped.
2014 Sunseeker
