Old 06-06-2016, 06:10 AM   #31
rmac04401's Avatar
They should make this a sticky.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 06-12-2016, 04:51 PM   #32
How do I get dvd to play on irv66. I have sound no picture
dkrecker is offline   Reply With Quote
Old 06-12-2016, 06:41 PM   #33
camaraderie's Avatar
Since you have sound, the VIDEO is playing. You're not getting it on your TV.
Possible causes:
1. The YELLOW plug cable from the radio is not plugged into a VIDEO input jack on your TV or it has fallen out.
2. The right VIDEO input source selection has not been made on your TV.
3, The Yellow Video cable is not plugged in to the right yellow jack on the back of the radio...or not plugged in at all. There are THREE yellow jacks you could plug into. TWO are VIDEO OUTPUT jacks 1 & 2....and one is a video input jack. You want to select one of the video output jacks. If you're not sure which is which...try all 3 one at a time with the TV set to the right video input.
4. Your yellow video cable has a break. Try a replacement directly.
5. If all of the above fails...you have a broken disc player output stage.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
dvd
