Old 04-26-2016, 07:33 AM   #1
No Video thru TV while playing DVD
Getting ready to take our new Grey Wolf 26DBH out for 1st time. Can hear audio thru DVD being played but no video to TV. Tried 3 different TV's. No luck. Your help/thoughts are appreciated.
mhc02 is offline   Reply With Quote
Old 04-26-2016, 07:40 AM   #2
I know on my setup there are separate video cables from the DVR player to the tv. Do you have those plugged in? Is the tv input set to the proper setting, either composite or component?
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 04-26-2016, 07:43 AM   #3
I used the cables that came with the unit. One set of AV R/Y/W cables that I plugged into the ceiling above the player and then into the back of the TV's. Also one set of same color with an AUX ending. Also tried those. And I checked multiple times to make sure I had each TV on the correct input.
Old 04-26-2016, 08:07 AM   #4
raspivey's Avatar
It's possible that the cables worked loose from the back of the DVD unit.
Old 04-26-2016, 08:12 AM   #5
How hard is it to remove the DVD player to check.
Old 04-26-2016, 08:28 AM   #6
raspivey's Avatar
I'm not positive on your unit. Shouldn't be too difficult. Mine has a Genesis 2 and you just carefully popped the faceplate off and it had four screws holding it in. Just slid it out a little from there.
Old 04-26-2016, 11:22 AM   #7
Menu
You have to go to the tv menu and select the source of the signal....it may appear as av .........the tv needs to know which signal to play.....
Bob Vaughn is offline   Reply With Quote
Old 04-26-2016, 11:31 AM   #8
I agree with the input/source. I had same issue took some time playing around but I finally got the right input. Also double ck your channel. Some work on tv 3, some on 4.
Good luck.
Pkowski is offline   Reply With Quote
Old 04-26-2016, 11:48 AM   #9
I'm confused why I would need channel 3 or 4. Never have I had to put any dvd player on any other TV in the house and had to put it on chanel 3 or 4.. I just select the approapite input (hdmi, component, AV1, AV2, etc) and it plays with video and audio. Like I said earlier, last night I tried all the input choices on the multiple TV and no video. Please explain why I need to put it on 3 or 4.
Old 04-26-2016, 12:06 PM   #10
raspivey's Avatar
You shouldn't need to on any TV made in the last 15+ years.
dvd
