Old 06-19-2016, 12:10 PM   #1
Noisy Dometic Fridge
The fridge in our 5th wheel cools fine but whenever the fan kicks on it does make noise. This has occurred sine it was new in March of 2015 and all my other rv refrigerators ran quiet. Is this anything I should worry about for our upcoming 3 week trip or just an inconvenience.
2014 Shasta Phoenix 32RE 5th wheel.
2015 F250 crew cab 6.7 Powerstroke 4X4.
clicker1944 is offline   Reply With Quote
Old 06-19-2016, 03:43 PM   #2
dcheatwood's Avatar
Depending on the model of frig, you likely have a fan mounted behind the frig accessible from the outside vent. Mine was screwed directly to the metal on the rear of the frig and caused a lot of metallic vibration, sounded like a high pitch squeal. I remounted it (and 2 more) onto a small piece of wood then attached the wood to the metal frig. Hardly noticeable now. Good luck. I can send you pic if you like.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
dcheatwood is online now   Reply With Quote
dometic, fridge
