You will need to run the set up routine and set the receiver for the 18 inch single lnb dish. The SD channels will work just fine. Make sure the receiver is not set to hide the SD channels. You will not receive your local channels and no HD. BTW you can pick up a slimline HD dish for about $75 and pointing it is only rough the first time...as it was for me. Now my 14 year old sets it up in about 10 minutes.
I used door shims to level the dish as the CG does not allow digging around the campsite. I need an easier way of adjusting the base for leveling. Perhaps some threaded bolts at each corner would allow me to adjust the angle. Any suggestions would be appreciated. For now I'll just use my shovel or a handful of shims.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
