Old 11-10-2017, 09:16 PM   #1
NORCOLD 1210 quits with "OP L1" code
My 18 month old Norcold 1210 stopped running about a week ago with an "OP L1" code, which means high temp limit switch has tripped. If you search the logs on RV.NET and HEARTLANDOWNERS you find out that this is a common problem caused by heavy rain or washing the trailer. Wonderful. Let's just hope it never rains on my trailer! There is a procedure to reset the switch using a magnet. I reset the switch using this procedure. So far so good. I had contacted both NORCOLD and THETFORD support and they both said I must go to an authorized service center. Try fixing it yourself first!
2016 Prime Time Crusader 322RES
2016 Ford F250 6.7L Diesel, Crew, 4X4, SRW, 3.55, Platinum, Ride Rite air bags
Reese Elite 18K Hitch
Nights camped 2016=47 2017=67
dennisewitte is offline   Reply With Quote
Old 11-11-2017, 09:27 AM   #2
SeaDog's Avatar
Its good you found a fix
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 11-12-2017, 01:55 AM   #3
spaach's Avatar
Pressure washing seems to be the worst. In the spring I probably see 3-4 of these a week come through the shop. I keep a step magnet in my pocket for this problem. It affects all 12xx series Norcold fridges including old stuff with the recall kit. 1200s lose power totally when tripped.
spaach is offline   Reply With Quote
Old 11-12-2017, 08:50 AM   #4
Any fix?
Is there a "fix" for this to avoid it happening? The reset with magnet is easy but it would be nice to avoid this from happening.
Old 11-12-2017, 11:25 AM   #5
spaach's Avatar
The best fix is not getting water inside the un-protected refrigerator compartment. Rain has yet to cause this on a rig coming through my shop. What actually happens when water is blown into the top vent is the insulation around the flue becomes wet. When the fridge is then turned on the water is heated to a point causing steam. The steam tricks the pyrometer into thinking the burner can is over 600 degrees (twice what it should be) and shuts the fridge down. Norcold did this incase of a rupture of the cooling unit at the heat source. If it cracks in a heat cycle it is possible to ignite the then leaking hydrogen gas and cause a vigorous fire that has caused more than one total loss of the vehicle.
Although not safe or recommended you can bypass the protection ability of this device taking the responsibility into your own hands. If you were to unplug and jumper together the red and blue wire at the thermal protection box it would be out of the loop and not be able to shut the fridge down in the event of water or catastrophic failure.
Bypassing this safety is never recommended due to the potential of fire. You can Google "norcold 1200 fire" if you want to see why they started installing these. It is even a retrofit to older models. I have done several hundred of these on earlier models for a few recall campaigns.
Old 11-12-2017, 01:48 PM   #6
I am pretty sure my "OP L1" was caused by a 1.5" rainfall with winds at 20 mph gusting to 30 mph and with ambient temperatures in the 60s. The refrigerator was running on electric.
You are absolutely correct about the importance of this high temp switch and that it should not be bypassed.
Old 11-12-2017, 06:23 PM   #7
spaach's Avatar
Ok, I totally understand the wind driven rain like that doing it. We don't usually see that in our season in northern California. Usually someone is careless washing.
We don't get crazy amounts of rain.
Old 11-24-2017, 12:24 PM   #8
Still working
Two weeks later the refrigerator is still running fine with no more "OP L1" codes!
