I have a norcold n811 in a 2015 Crusader 295 rst im tying to remove to change the fan. Found 2 screws in the top...2 in the bottom, and 2 in the bottom rear. Frig wont budge. What am i missing? Any help appreciated.
Any way you can get behind the refer, might be sone screws behind it keeping it from moving, if not then I bet you didn't find them all double check make sure you found them all, if all are removed and gas line is discontinued you should Ben able to move it some what but most likely will be a tight fit
Ok..got it out. Total of 6 screws, and about half a tube of silicone. Had a blob under each rear corner about the size of a golf ball. It apprears they dont want to leave any silicone in the tube once they oprn it, snd just apply it randomly.
