Old 08-10-2016, 04:47 PM   #1
Norcold refrigerator question
I have a Norcold model 1210 refrigerator that is approximately one year old. I've noticed at different times that the interior temp and contents gets considerably warmer than what I'm used to or expect.
The refrigerator is always on the automatic setting and always left running. Once it starts cooling it will get to the desired temps and stay there but then fail to start back up again for awhile. I started watching it close at home and it stopped cooling completely. I shut it down for the day then turned it back on. It started cooling down with the freezer getting back below freezing. After getting to that point it started warming again.
Anyone else had this problem with their frig? The vent fans are working and the frig does not show any failure codes. Could it be some type of switch or sensor that isn't to the point of showing as failure but obviously not working right? This is my 4th camper with a frig and so I think I know what to expect from one.
The frig is still under warranty and I have contacted my dealer. I'm on the wait list but I thought maybe there was a fix that someone else may know about.
Steve and Kim
Southern Illinois
2015 Sanibel Traveler 33RS
2011 F350 SRW Crew Cab
si camper is offline   Reply With Quote
Old 08-11-2016, 01:56 PM   #2
Have same refrigerator and it died on me after a while no more cold even freezer would not work dealer check refrigerator and cooling unit need to be replace but some food was spoiled inside very bad smell and had the trailer 13 months trailer manufacturer warranty is expired (12 months) now dealer is in contact with Norcold to get replacement for a new unit awaiting their reply
2016 Spartan 1234X Trail-Air Pin Box...thermo windows...12 cu.ft frig....3 seasons patio door
2011 Ford F-250 Super Duty Power Stroke King Ranch 4X4 diesel
Pierre Allard is offline   Reply With Quote
refrigerator
