My Norcold fridge works well in general. Gets cold stays cold on both electric and gas. Problem I have is a periodic failure to relight. on gas. Generally lights on first click of the igniter but occasionally you'll hear the "boinking" noise of the burner trying to light but failing. (Only word I can think of to describe the sound it makes ). You can hear the igniter firing okay. Any suggestions?
I would clean the igniter and the gas nozzle and blow out the burner tube with air and see if that doesn't take of the bonking
Will try that. New so may have construction dust in the burner. Did have an igniter gap situation on the maiden voyage that I was able to correct. Pretty sure I've got that correct now, but?
