Old 04-20-2019, 07:03 PM   #1
JPin AZ's Avatar
Not a good idea to use this to run AC?
I have done it before with my old TT. It was hot today so I thought I would try the AC in my new 2011 ROO 23ss while working inside. AC blew cold until I turned it off. It did not want to restart. After sitting it did restart but I did not run it because I was afraid I was going to kill it. Thoughts?
John
2003 1500 Avalanche 357,000 miles
2011 Rockwood ROO 23SS
JPin AZ is offline   Reply With Quote
Old 04-20-2019, 07:18 PM   #2
dieselbobcat's Avatar
High head pressure. Might have been off on limit... there is also a timer to prevent short cycling.
What were the ambient conditions?
What was the duration between shutting it off and you trying to restart it?
2014 Rockwood Ultralight 8312SS Diamond Edition
2016 F350 Lariat Ultimate Super Duty Crew Cab 4X4
Northern NJ - God Bless America!
dieselbobcat is online now   Reply With Quote
Old 04-20-2019, 07:23 PM   #3
JPin AZ's Avatar
94 Degrees ran it for 30 plus minutes. Restart almost immediately.
John
Old 04-20-2019, 07:23 PM   #4
Retired Old Fart
dward51's Avatar
Probably still had pressure in the compressor when it tried to kick back on. They can start pretty much every time when it's been sitting as there is less pressure built up in the compressor. On the lower amperage line, it did not have enough "umph" to kick over the compressor at the initial surge. I would not do that much as you can damage the compressor.
If you are going to run one like that, I would make sure to start it with the thermostat set high enough so the fan comes on first then lower the setting so the compressor kicks on. If the fan and compressor both kick on at the same time, it draws more amps. If you can manually set your fan to on, it may restart on yours. But it's better to use a proper amperage outlet (also if you have a 20 amp available instead of 15 it would be better than the 15 in the photo above).
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is offline   Reply With Quote
Old 04-20-2019, 07:35 PM   #5
JPin AZ's Avatar
Thanks for the quick replies. I have only ran the AC a couple of times plugged into the house. I thought I would be okay using the heavy TT cable. I will not do this again. Years ago i knocked 220v in this box down to 110. I might have to research if I can add 30 amp using the unused wiring in the box.
John
Old 04-20-2019, 07:36 PM   #6
JPin AZ's Avatar
We have a local trip planned next weekend it sounds like my AC will be fine plugged into 30 amp.
John
Old 04-20-2019, 07:39 PM   #7
wmtire's Avatar
I don't imagine you even have 15 amps available to the RV as I can see other items plugged in beside the outlet your RV is plugged into.
Mark Polk has a good article on this:
Basic RV Electricity - RV Information (RV Maintenance)
2011 Flagstaff 831 RLBSS
Never Apologize! Never Explain!
Sorry, thatís my motto.
Old 04-20-2019, 07:41 PM   #8
JPin AZ's Avatar
True, cordless drill charger not being used and boom box that was running.
John
Old 04-20-2019, 07:43 PM   #9
JPin AZ's Avatar
I guess the question is does a breaker limit amps before tripping?
John
Old 04-20-2019, 07:49 PM   #10
western NC mountains!
formerFR's Avatar
a breaker is a 'heat' sensitive device, and there's no way for it to in any way 'limit' anything until it trips from 'overheating', which is it's design.
using a 15a or 20a outlet is perfectly fine for powering a 13.5 or so air conditioner, as it draws 12-13 amps even at full bore.
if it worked for a while, then you've proved the point.
why didn't it restart?
well, you said it blew cold... so maybe it just froze up, right as you initially turned it off, which requires sometimes a long wait before it will power back up.
your adapter, the 30a to 15a block adapter, simply allows you to plug into a 15a outlet, that's all... otherwise there's no difference from plugging the air conditioner into the 15a outlet directly... it's a maximum of 15amps.
formerFR is offline   Reply With Quote
