Old 08-02-2012, 03:43 PM   #1
? on Dometic 2852 fridge temp setting
While in the process of defrosting the fridge fins I noticed the probe that is supposed to be in the temp setting slider came out. OK, no big deal, just slid it back in. My ? is should the top of the probe be flush with the top of the slider, in the middle, or flush with the bottom? And yes I looked in the manual but no mention of where it should be. TIA for your help.
Old 08-02-2012, 03:54 PM   #2
TURBS's Avatar
I put my probe at the top of the slider .
Works fine!
Old 08-02-2012, 04:11 PM   #3
Herk7769's Avatar
It is the temp control for the lower fridge. Slide it up and down till the lower compartment keeps the beer cold without freezing the eggs.
HAM CALLSIGN - KC3FFW
Old 08-02-2012, 04:16 PM   #4
TURBS's Avatar
nothing wrong with a little frost on the beer either .
Old 08-02-2012, 04:52 PM   #5
Thanks turbo and herk. Top of the slider is where I'll put it. And I too like my drinks ice cold.
Old 08-02-2012, 05:33 PM   #6
TURBS's Avatar
Good luck!
Have a frosty one on me!
Old 08-09-2012, 09:22 PM   #7
phat phrog stunt crew
best written tech advice ever. should be nominated as sig of the week
dwaynerz is offline   Reply With Quote
Old 08-10-2012, 02:57 PM   #8
so, if the freezer is cold enough to freeze water, but the refrigerator is too warm, the white wire with probe on end needs to be higher on the fin? Mine does not have a clip and just droops near the plastic pan which is below the fins. It seems from all the posts I have found, that the higher the probe in the refrigerator, the cooler the refrigerator gets??? and if so I need to get a clip to keep my probe higher on the fin.
LLM>2003 F250 supercrew 6.5 ft box, 4x4 6.0 powerstroke, 6 speed automatic, slide in camper certified.
2005 FR Wildcat, replaced original with quick and nimble (sidewinder) kingpin box, husky 15k hitch
still-learnin is offline   Reply With Quote
Old 08-10-2012, 03:30 PM   #9
Still-learnin, you are correct, the higher the probe, the colder the fridge. If the clip is missing, I would find or fabricate one.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 08-10-2012, 04:59 PM   #10
VinceU's Avatar
Should be clipped to fin, in contact, to work properly.
