Old 07-26-2019, 12:15 PM   #1
OneControl/MyRV LincHub router location?
We bought a (very very lightly used ... 2700 miles!) 2018 Forest River MBS 2401W motor coach from a private seller. The coach has the MyRV/OneControl tablet controller (the smaller 7" one it appears).
Works fine, but I want to connect to it with my iPhone. To do that, I have to get on its WiFi "network" BUT ... the previous owner has no idea what the password is (and didn't even know it had an option for an App) so I assume that I need to find the LincHub router and get the default password off it.
Problem is, I have NO IDEA where it might be mounted in the coach!
I've looked in the panel behind the control panel and the inverter/fuse/breaker controller and in all the cabinets, but haven't found it yet. Anybody have an idea where to find it so I can connect my App? I just need the sticker from the hub which looks like it has the SSID and password printer on it from the pictures I have found?
EDIT: See attached picture ... it appears this might be the receiver and I was looking for the wrong thing? I still have the same problem though ... can't get into the network without a password (I *DO* see the network ... it shows up as MYRVblahblahblah (numbers and letters)
Part number seems to be: MyRV RECEIVER CONTROL BOARD 18449, 344920
kenmosher is offline   Reply With Quote
Old 07-26-2019, 12:27 PM   #2
One Control
Hello, I'm not sure where they mounted your hub or range extender for the ssid, but here's the PDF to reset everything. Hope this helps a little https://lci-support-doc.s3.amazonaws...cd_0001439.pdf
JoePK is offline   Reply With Quote
Old 07-26-2019, 12:31 PM   #3
Awesome info!
So either this controller board is older OR I need to still keep looking for the actual wifi hub that looks like the one in the docs you posted?
Old 07-26-2019, 12:38 PM   #4
Hub
Yeah, take a look around/up and down your storage areas, including the outdoor storage. If you have an inverter in that model, it's probably around there somewhere. I found my info on a sicker inside one of my cabinets.
Old 07-26-2019, 12:46 PM   #5
UPDATE! THANKS A MILLION ... so found the sticker in the back of the cabinet by the microwave. Along with fuse panel layouts and so on ... EXCELLENT. Connected and we're golden. Thanks again!
Old 07-26-2019, 04:05 PM   #6
Great!
location, cat
