Old 09-11-2014, 09:03 PM   #21
RKR
RKR's Avatar
Open Ground Code Still
It's right next to the main OC. They tied into the main and added a box because there wasn't any lugs available on the breaker panel in the garage. I knew double lugging isn't a good practice.
I'm looking forward to getting this resolved and sharing the solution though. I ain't no lectrician for sure
Sent from my high tech gadget
RKR is offline   Reply With Quote
Old 09-11-2014, 09:12 PM   #22
Me either, that's for sure! I've just seen the neutral and ground connected in a lot of main boxes. Have no idea if that is causing your problem.
Old 09-11-2014, 09:40 PM   #23
B and B's Avatar
Often the Neutral Bus bar has a extra screw that ties it to the ground via a box connection. Look for a bonding screw on the bus bar.
If the ground and neutral are actually tied together at your new box that is the same as the service entrance as far as the Progressive is concerned. Are there any LED lights in the cable or the power entrance port on the RV? Maybe they are providing a leakage path?
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 09-11-2014, 10:11 PM   #24
RKR
RKR's Avatar
B and B , I don't have an LED light on the crossover . I'll check that bus bar in the morning. Hopefully it's the crossover from 50 to 30 amp that's giving me problems. It's the original one the dealer gave me when I bought the 5er.
If I bypass the EMS everything runs fine. I let the 5er plugged in for 2 days and ran the AC for one day.
Old 09-12-2014, 07:04 AM   #25
mud yapster's Avatar
My install last night went well without a hitch. Mine didn't come with the jumper wire for the time delay so I'm going to call Progressive and ask them about it. My time delay isn't but a few seconds before the surge protector kicks in and I'd like a longer delay than that. Here are a couple pics of my install. Hope you got yours fixed RKR. Oh and the wires above the Surge Protector are just Satellite cables. I wired mine coming out of the transfer switch so I would have surge protection from the generator and shore power.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 09-12-2014, 07:23 AM   #26
RKR
RKR's Avatar
Looks great bud. It looks like you at least one water line near yours. I have many. My hot water heater and water source is next to the outlet. I have all kinds of water lines in my compartment. I could of installed my EMS on the floor but opted for the wall to try and minimize the risk of the EMS getting wet if I spring a leak. I'll probably install some type of cover over the EMS in case I get a leak some day.
I still have my open ground issue. Had a late day at work yesterday so I couldn't do anything. I'll be back on it today for sure.
Old 09-12-2014, 07:30 AM   #27
Yes there are several water lines in my compartment over the transfer switch and probably my new EMS also but if I spring a leak .
Hope your able to get your issue solved. Have you called the tech support at Progressive yet. You'll need to be at your RV when you call them. I'm sure they would be glad to help you with it they are real good at customer tech support.
Old 09-12-2014, 10:47 AM   #28
RKR
RKR's Avatar
Yapster, I haven't called Progressive yet. From the intel here and other sources the issue is before the power gets to the EMS.
It looks like my retired electrical contractor neighbor is back from fishing. His pickup was in the driveway when I left for work this am. Hopefully he'll be home when I get off work. He has all those fancy gadgets for tracking stuff down and I'm going to have him check the main box that new one is tied to for problems.
Those water lines are in a crazy place. My inverter would also be screwed if I had a good leak. I will pull down that divider wall next time and take look before I buy the next 5er. If I decide to keep this one for any length of time I'll probably look at trying to re-route the water lines somehow.
Old 09-12-2014, 12:21 PM   #29
That's good hopefully he can fix your issue for you.
Old 09-15-2014, 07:07 PM   #30
RKR
RKR's Avatar
Update :
After swapping 50 to 30 amp crossover with one from Progressive still open ground code.
I had my retired electrical contractor neighbor come over with his volt meter and check everything. Everything is wired correctly all the way back to the box. We called Progressive and the neighbor and I followed their trouble shooting steps and still get the open ground code.
Sending unit back to Progressive for replacement.
