Old 09-15-2014, 07:36 PM   #31
mud yapster's Avatar
Maybe the unit is bad then. Hope that new one does the trick. I've had mine hooked to the power pole ever since my install. I think its cool seeing the read out and gives me piece of mind. Good luck let me know how it goes.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 09-15-2014, 08:15 PM   #32
RKR
RKR's Avatar
For sure bud. I have no ill feelings toward Progressive. The tech took my call after 5 and was helpful and I learned a few things. It should install easier next time with the wires already cut and stripped.
I'll update again after the next install.
Sent from my high tech gadget
RKR is offline   Reply With Quote
Old 09-15-2014, 08:16 PM   #33
mcnabbwr's Avatar
If I missed this suggestion in any of the previous post I apologize, but have you turned all breakers in the RV off prior to turning on the main? If you isolate all circuits first then turn them on one at a time you may find the one causing the fault.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 09-15-2014, 08:27 PM   #34
RKR
RKR's Avatar
Thanks bud. Progressive says the issue isn't on the output side of the box and we checked everything back the main source.
I will give your idea a shot though. I have nothing to lose. I haven't taken the box out yet. I'll turn off all the breakers and leave the main on and see what happens.
Old 09-16-2014, 05:58 PM   #35
AquaMan's Avatar
The problem isn't in the coach, it's either in the power source or the EMS itself. Turning off breakers in the RV does nothing.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 09-16-2014, 07:45 PM   #36
RKR
RKR's Avatar
Yup, the breaker thing didn't work either but it was an easy idea worth a shot.
The EMS is hopefully coming out tomorrow if I get time. I'll post when I get the new one installed.
Thanks for everyone's ideas.
Old 09-27-2014, 02:23 PM   #37
RKR
RKR's Avatar
Update:
Progressive received my EMS box last Monday and it arrived back to me Friday. It was the board after all. I just got back today from a 2 day trip. Will have it installed maybe tomorrow morning for sure Monday. The pic shows what they found wrong.
I'm pretty impressed with them backing their work.
Name:	ImageUploadedByForest River Forums1411845798.851102.jpg
Old 09-27-2014, 02:50 PM   #38
mcnabbwr's Avatar
Great service from the manufacturer, and glad you got it resolved.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
Old 09-28-2014, 10:11 AM   #39
RKR
RKR's Avatar
Last update:
Progressive 50 amp EMS installed and working fine. Sure glad Progressive got to it and sent it back in very timely manner.
Onto to next mod. It'll probably be this flimsy basement wall. Click image for larger version
Name:	ImageUploadedByForest River Forums1411916877.055336.jpg
I can't see it holding up in the long run. Looks like I got room for a 2x2 wall. Just need to figure out a better way to mount it in there. Something solid and quick release type.
