Old 05-12-2014, 07:49 AM   #1
Outdoor fridge, proper shutdown
There's a little freezer in the fridge. What do you folks do knowing it will defrost when you end your camping vacation?
I threw a towel below it and when I docked home, opened the outside fridge and removed the towel. It was soaked.
2014 Flagstaff 831BHDS
2010 Ram 2500 Cummins 4.10s - Superchip'd
Built-in Controller
Hellwig Sway Bar 7272
Equalizer Hitch system
Long Islander is offline   Reply With Quote
Old 05-12-2014, 07:53 AM   #2
Put a hole in the drain pan and attach a connector with tubing that goes around the side to a drain bottle that you can access and empty
OKI Marine is offline   Reply With Quote
Old 05-12-2014, 09:16 AM   #3
Drain pan? I dont see any drain pan in the fridge.
Built-in Controller
Old 05-12-2014, 11:15 AM   #4
TURBS's Avatar
Mine has a drain pan to .....
But I can never get it out because the door doesn't open up far enough to allow it to.
TURBS
Sabre owners united!
Old 05-12-2014, 11:55 AM   #5
I owe it all to bacon.
Eklc's Avatar
I let it sit with the door open and put towels, newspaper or a chamoise in the bottom while it defrosts. After that I prop it open so it wont mold.
Eklc is offline   Reply With Quote
Old 05-12-2014, 07:43 PM   #6
Interesting, some have drip trays, while mine does not
Built-in Controller
Old 05-12-2014, 08:19 PM   #7
Camping Buddys's Avatar
Mine also have the drain pan, what we do is this, the last morning of the camping trip the fridge is empty or almost empty, (we take whats left and moved it inside)we unplug the power leave the fridge door open a little and by the time we leave the campground is dry. Wipe it down with paper towel and it's done and clean until next trip. And this is how it looks after a year and a half!
John, Lilly & the kids.
2013 Surveyor Select SV 305
2011 Toyota Tundra crew max 5.7
http://campingbuddys.shutterfly.com/
Camping Buddys is offline   Reply With Quote
door, fridge
