Old 06-30-2019, 02:12 PM   #1
Outdoor TV mount and bracket
Does anyone know where I can buy a matching tv mount for this outside tv bracket? The bedroom tv is the only one that has a matching bracket (of the three tv's in the trailer) and we would prefer to leave it inside and use a larger one for outside. Hopefully the pic comes through...
TIA.
2018 Rockwood Signature Ultra Lite 8311WS
Chazman is offline   Reply With Quote
Old 06-30-2019, 02:21 PM   #2
ejohnson1144's Avatar
Usually the mount coinsides with tv size
ejohnson1144 is offline   Reply With Quote
Old 06-30-2019, 03:10 PM   #3
TV mount
Ah..... makes sense, but these new tv's seem to be pretty light. Not sure what the weight difference is between a 24 and a 32 inch. I'll have to check.
Thanks for your reply!
Old 06-30-2019, 03:17 PM   #4
Oaklevel's Avatar
Try here just scroll down. Our TVs had the same mount.
https://www.ramco-eng.com/extending-mounts
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 06-30-2019, 03:25 PM   #5
There it is
The MQCE220, thanks very much!
Old 07-01-2019, 04:42 PM   #6
Oh 24 to 32 you are probably allright then I was thinking from a 19 or so.
Old 07-01-2019, 04:59 PM   #7
They also make a non-articulating model that just has a flat plate that mounts to the TV.
TV Quick Disconnect Flush Mount, Removable face plate, RV's up to 200x200 - 4
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 07-01-2019, 06:06 PM   #8
I had the same issue. Take the TV down from inside with the similar bracket and look at the bracket attached to the back of that TV. I forget what the manufacturer is but there is a small place where the manufacturers name and model at embossed. Google the manufacturer and hopefully find what you are looking for.
Once you have the manufacturer name you might even find it on Amazon.
RkwdNewbie is offline   Reply With Quote
door, mount, outdoor tv, tv mount
