Old 09-03-2011, 11:38 PM   #1
Bill_C's Avatar
Outside coax connector
We have an outside coax connector for camp ground TV connections. There is a flip up cover that exposes the male coax connector. My problem is the threads on the connector are recessed to far into the trailer wall. Hooking up a threaded coax cable is really difficult as there is no room in the box to get our fingers into. I have been looking for a short 2 foot extension cable that just pushes on, no turning of any nuts required. I'll then connect my regular cable to the short extension.
Has anyone else had this problem and how did you solve it, any idea where to get a short extension like the one I describe ?
DRINK COFFEE--do stupid things faster and with more energy ! Rockwood 5th wheel, Signature Untralite, 8244S
Tow Vehicle: Ram 3500 6.4 litre Hemi.
Bill_C is offline   Reply With Quote
Old 09-04-2011, 12:23 AM   #2
one day at a time
Idle_Idylist's Avatar
something like this would work well i think
Slotted Wrench / Shield Key
or they make one that is on a screwdriver type handle
2012 Ford F250
2016 Salem 27Dbud
Blue Ox BXW1000 WDH
Idle_Idylist is offline   Reply With Quote
Old 09-04-2011, 01:16 AM   #3
flyrotor's Avatar
You can get push on cable wires for televisions at places like Walmart and Best Buy, they are usually about 4' long, then get a connector to join the two together
flyrotor is offline   Reply With Quote
Old 09-04-2011, 06:50 AM   #4
Herk7769's Avatar
I use this. It works great. I have in my home and camper tool kit.
Coax Cable Tools 7/16in F Type Connector
HAM CALLSIGN - KC3FFW
Old 09-04-2011, 08:10 AM   #5
Bill_C's Avatar
Coax tool
Thanks everyone. Who would have thunk there was even a tool available for this?? I had checked every Walmart and electronic store I saw for the push on cables, none were available. So, shopping I will go to the electronic stores. I love tools!
Old 09-04-2011, 08:18 AM   #6
I changed the F-connectors to quality connectors which are often larger nut area allowing you to get your fingers on them. It is probably more expensive as you need the "crimp tool" and the connectors. I had them all from being in the business. I do not like store bought cables as they put that plastic strain relief on the end and the nuts for the f-connector are so small. The store cable you are buying is very cheap quality and not made to make multiple hookups and removals. They are made to hookup once and leave them be. Just remember, each time you add a connection, you loose approx 3dB of signal. The more connectors, the weaker the signal at the receiver. Try to friend "the cable guy" or a satellite guy and see if they will make you up a cable to length. I used to do it all the time. Good customer relations! One other thing about the type of cable, as you look at the center of the coax, you will see that it is solid. Everytime it moves, it weekens the center conductor. Think of repeated bending of a piece of metal will eventualy break off. In coax, you may not realize the center is broken. Try to stick with a quality cable.
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
Old 09-04-2011, 08:22 AM   #7
jimh's Avatar
radio shack is a good source for the pig tail.
i like those tools. i have a couple vcrs and tv's that like to put a little tab next to the coax connection. real pain nursing that fitting when ur trying to reach around.
jimh is offline   Reply With Quote
Old 03-21-2013, 01:37 PM   #8
gbpacker's Avatar
Push on Connector
I know that this is a little late, but if you are still looking for a simple solution to your problem you may want to try these connectors instead of a pigtail.
Gold Series Screw-On to Push-On F Connector Adapter : Adapters | RadioShack.com
I added these to my regular cable to solve the exact problem you identified, and no tools are required other than the initial installation.
gbpacker is offline   Reply With Quote
Old 03-21-2013, 01:55 PM   #9
Use a similar one except it is 90 degree one.
